    Unsolved Display filename on 12864
    213
    • KP0005
      KP0005 last edited by
      Is there a way to display the name of the file (gcode/macro) that is currently being printed on the 12864 display on a Maestro?
      • PaulHew
        PaulHew last edited by
        Looking at this, https://duet3d.dozuki.com/Wiki/Duet_2_Maestro_12864_display_menu_system, I do not think there is a way.
        You can list files on the SD card to select and print, but not display current file printing.
        RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
        Voron 2.4 disassembled..... Waiting for the RailCore Mini....
        KP0005 1 Reply Last reply Reply Quote 0
        • KP0005
          KP0005 @PaulHew last edited by
          @PaulHew I was using that site as a guide when making my menu files but not all the features of the menu system are documented. For example, you can chain commands in the "A" section of an "action" using | to indicate the next command, which is something I couldn't find anywhere in the documentation.
            dc42 administrators @KP0005 last edited by
            @Matej101 said in Display filename on 12864:
            Not currently. But fairly soon in RRF3 you will be able to display anything that is in the object model.
            DIY-O-Sphere KP0005 2 Replies Last reply Reply Quote 0
            • DIY-O-Sphere
              DIY-O-Sphere @dc42 last edited by
              @dc42 said in Display filename on 12864:
              Hi David,
              if you are making changes in the display menu system, do you think it would also be possible to expand the image command to behave like a button?
              I would prefer to click the image directly to execute an action, instead of placing a separate button near the image.
              Regards
              Frank
              (UTC+1)
                Yes I can do that.
                DIY-O-Sphere 1 Reply Last reply Reply Quote 0
                • DIY-O-Sphere
                  Yes I can do that.
                  Awesome!
                  (UTC+1)
                  • KP0005
                    KP0005 @dc42 last edited by
                    @dc42 Thanks, I'll be looking forward than!
