    Strange Behaviour in RRF3.0
    508
    • chas2706undefined
      chas2706
      Hi
      I suddenly have a problem with my bed heater config. I don't understand what has gone wrong apart from the issue seems to have appeared after upgrading to the latest stable version of RRF3.0.
      Without changing any of the original gcode in the config I get error message "Heater0 not defined".
      Here is a snippet of the heater/thermistor set up that was originally working but is now not!
      ; Heaters/temperature sensors
      ; Bed
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      ; Nozzle
      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
      M307 H1 A299.8 C109.4 D4.0 S1.00 V12.3 B0 ; Autotune result for hotend
      M307 H0 A109.8 C457.8 D2.1 S1.00 V12.3 B0 ; Autotune result for bed
      I have found that if I comment out the M307 autotune result for the bed the error message disappears. If I do a re-tune and re-enter the results, the error "heater0 not defined" comes back.
      BTW what is the M140 command doing in there?
      It was auto generated by the configurator. The comment says "map heated bed to heater 0 but if I look up the command in the Gcode documentation it says "M140: Set Bed Temperature (Fast)" !!!
      If I comment out the M140 command, the bed heater disappears from the DWC!
      So summing up, what I have now is a working bed heater with a commented out autotune set up for it and a strange M140 command that somehow needs to be there!
      Anyone have any ideas?
      Thanks in advance.
        jay_s_uk
        M950 has to come before and M308's
        See https://duet3d.dozuki.com/Wiki/Gcode#Section_M950_Create_heater_fan_or_GPIO_servo_pin
        • chas2706undefined
          chas2706
          @jay_s_uk
          Ok thanks I will correct it but the configurator put it in that order!
          Any ideas on the need for the M140 command with the false description?
            jay_s_uk
            I would suggest that the M140 can be disabled.
            I don't have one in either of my machines configs
            • chas2706undefined
              chas2706
              @jay_s_uk
              This is what I now get by making those changes:
              Here is my full config.
              ; generated by RepRapFirmware Configuration Tool v2.1.1 on Mon Nov 04 2019 16:21:57 GMT+0000 (Greenwich Mean Time)
              M555 P2 ; Set Marlin-style output
              G21 ; Set dimensions to millimetres
              M550 P"Duet3" ; set printer name
              M558 P0 S1 ; Enable http
              M586 P1 S1 ; Enable FTP
              M586 P2 S1 ; Enable Telnet
              M669 K1 ; select CoreXY mode
              M569 P0 S1 ; X physical drive 0.0 goes forwards
              M569 P1 S1 ; Y physical drive 0.1 goes forwards
              M569 P2 S0 ; Z0 physical drive 0.2 goes backwards
              M569 P3 S0 ; Z1 physical drive 0.3 goes backwards
              M569 P4 S0 ; E0 physical drive 0.4 goes backwards
              ; Set drive mapping
              M584 X0 Y1 Z2:3 E4 ; Dual Z make sure drive 2 is left hand Z and 3 is right hand
              M92 X80.00 Y80.00 Z400.00 E96.00 ; set steps per mm
              ; Accelerations, speed and jerk
              M98 P"/macros/print_scripts/default_speed.g"
              ;M566 X600.00 Y600.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min) - Jerk
              ;M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; set maximum speeds (mm/min)
              ;M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2) (print moves)
              M906 X1000 Y1000 Z1000 E1100 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              ; Leadscrew positions: The measurement is taken from X=0, Y=0. Therefore X will be negative, Y positive and middle of bed = 160
              M671 X-100:415 Y160:160 S2.0
              M208 X-15 Y-12 Z0 S1 ; Set axis minima (adjust to make X=0 and Y=0 the edges of the bed)
              M208 X310 Y310 Z380 S0 ; set axis maxima
              M574 X1 S1 P"!io0.in" ; configure active-low endstop for low end on X via pin io0.in
              M574 Y1 S1 P"!io1.in" ; configure active-low endstop for low end on Y via pin io1.in
              M581 P"^!io2.in" T0 C0 ; configure active-low endstop to perform an e-stop and let it trigger at any time without restrictions
              M581 P"!io4.in" T2 C0 ; configure active-low switch to perform filament unload macro
              M581 P"!io5.in" T3 C0 ; configure active-low switch to perform filament load macro
              ; Filament Run Out Sensor
              ;M591 D0 P1 C4 S1 ; Code requires conversion Filament runout Sensor for Extruder E0 P1 = signal HIGH.
              M558 P1 C"io3.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
              ; G31: the P is the reported Z value when triggered. X,Y are offset coordinates. Z is trigger height, you can decrease value if nozzle is too close
              ; or increase if too far away.
              G31 P500 X-30 Y-5 Z2.18 ; set Z probe trigger value, offset and trigger height
              ; Mesh Grid
              ; The following M557 commands are not needed if you are using a bed.g file to perform bed compensation
              ;*** Adjust the XY coordinates in the following M557 commands to suit your build and the position of the Z probe
              M557 X10:280 Y20:280 S50 ; Define small mesh grid
              ;M557 X10:280 Y10:280 S20 ; Define large mesh grid
              ; Bed thermistor/heater
              M950 H0 C"out0" T0 ; bed heater H = heater no. C = output T = temperature sensor no. defined below.
              M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; bed thermistor
              M143 H0 S120 ; set temperature limit for bed heater 0 to 120C
              ;M140 H0 ; map heated bed to heater 0 ??????????????
              ; Extruder thermister/heater
              M950 H1 C"out1" T1 ; ext heater H = heater no. C = output T = temperature sensor no. defined below.
              M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; extruder thermistor
              M143 H1 S280 ; set temperature limit for extruder heater 1 to 280C
              M307 H0 A108.4 C735.4 D1.4 S1.00 V12.5 B0 ; Autotune result for bed
              ;CPU Temperature Calibration
              M912 P0 S-10.0
              ;M308 S20 Y"mcu-temp" A"CPU" ; Defineix sensor S20 for CPU temperature
              ;Expansion pins
              ;M307 H2 A-1 C-1 D-1 ; Code requires conversion Make heater2 on extruder2 available and use it for pwm led lighting
              M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency (parts fan)
              M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency (ext fan)
              ;Re-assigned fan pins
              ;CPU fan
              M950 F2 C"out9" ; create fan 2 (CPU fan)
              M308 S3 Y"mcutemp" A"mcutemp" ; set up a virtual sensor for cpu fan
              M106 P2 T30 H3 ; set fan 2 value. Fan comes on when cpu temp is above 30 degrees (Cool the pi as well!)
              ;Led Lighting
              M950 F3 C"out4" Q500 ; create a fan 3 output to use for led lighting control on pin out4
              M106 P3 S0 ; set output default to off
              M563 P0 S"Extruder0" D0 H1 F0 ; define tool 0
              ; Custom settings
              ;M912 P0 S-15.8 ; Find correct value
              ;M42 P2 S255 ; Turn led lighting on full
              ;M98 P"LevelLeadscrews.g" ; Option to perform leadscrew levelling
              ;M98 PEnable Mesh Levelling ; Option to enable on start up
              T0 ; select first tool
                jay_s_uk
                You can remove "M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit"
                As you have the correct PWM settings on the row below.
                Nothing else jumps out as being incorrect though
                • chas2706undefined
                  chas2706
                  @jay_s_uk
                  This is strange. I have removed M307 and here's what I get...
                  This is with command M140 commented out.
                  No bed heater showing in DWC!
                  ..and here's with M140 back in.....
                  Still config error messages showing but heaters are working!!
                  But, if I put the M950 commands for both the bed and extruder AFTER the M307 commands AND the M307 autotune settings commented out for the bed heater I get this...…
                  All heaters working, no errors but no autotune settings available for the bed heater!!!!!
                    jay_s_uk
                    Odd.
                    Might be one for @dc42 to jump in on
                    • chas2706undefined
                      chas2706
                      @jay_s_uk
                      What is really odd is that the RRF Configurator puts the M140 command in and also puts the M950 commands AFTER the M307's and I cant get the heaters to work in any other configuration!
                      Thanks for your valued help and suggestions.
                      David have you any suggestions on this?
                      • chrishammundefined
                        chrishamm administrators
                        This post is deleted!
                          dc42 administrators @jay_s_uk
                          @jay_s_uk said in Strange Behaviour in RRF3.0:
                          No, M308 should come before the M950 that uses it, so that the sensor number used in the T parameter of a M950 H command already exists. OTOH any command that refers to a heater or fan number must come after the M950 command that creates that heater or fan.
                          • chas2706undefined
                            chas2706
                            Even with that though I cant get my bed heater to show up on DWC or work without the M140 (set bed temperature) command that RRF configurator put in and the M307 autotune settings commented out.
                            • chas2706undefined
                              chas2706
                              What does the command M140 H0 actually mean?
                              It is not documented.
                                dc42 administrators @chas2706
                                @chas2706 said in Strange Behaviour in RRF3.0:
                                It's mentioned at https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M140_Set_Bed_Temperature_Fast but not well documented. It tells RRF that the first bed heater is heater 0. I'll add some more examples to the documentation.
                                • chas2706undefined
                                  chas2706
                                  OK thanks.
                                  In my current config I have the commands in the correct order and includes the M140 command. All is well unless I uncomment my autotune setting for Heater HO.
                                  The actual settings are:
                                  When uncommented I get this:
                                  Thanks in advance.
                                    M307 must come later in config.g than then M950 command that creates that heater.
                                    More generally, where a command references some entity (e.g. a heater, fan, sensor, GPIO port, or additional axis), that entity must be created first. Example:
                                    M308 S2 ... ; create sensor 2
                                    M950 H0 T2 ... ; create heater 0, uses sensor 2
                                    M307 H0 ... ; uses heater 0
                                    M140 H0 ; uses heater 0
                                    • chas2706undefined
                                      chas2706
                                      Thanks David that works great now!
