    Z Probe Trigger Height G30 S-1 height changing every probe
    1.9k
    • Turboundefined
      Turbo
      okay so current looks fine. you could try bumping up by a factor of 50 to 100 and see if you get any changes, but I'm not sure about that one.
      you could also adjust the electromagnet on the bltouch by tightening/loosening the allen screw on top, again, not sure, but im throwing things out there that might help.
      Cant stop tuning wont stop tuning.
      Dbot, Custom i3, Voron 0&2
      apex2011undefined 1 Reply Last reply Reply Quote 0
      • apex2011undefined
        apex2011 @Turbo
        @Turbo thanks! I'll give those a try
          Also might help to check the tension on your V wheels on the Z carriage. Check the lead screw nut as well to see if it's loose in its mount or something. Check the lead screw coupler too. And Z motor mount.
          It was asked earlier, but are you testng with the bed warmed up? Have you PID tuned the bed heater? Running the bed heater in bang-bang mode can cause the heating plate to flex slightly as it cycles current through it. Hard to probe a moving target.
          • apex2011undefined
            apex2011 @Phaedrux
            @Phaedrux I just checked the tension on the V wheels, it looks good, there's no play on the rail. I have done PID tuning. I have been testing with the bed cold
              Firmware version?
              • apex2011undefined
                apex2011 @Phaedrux
                @Phaedrux Firmware 2.03 (2019-06-13b2)
                Web 1.22.2
                • apex2011undefined
                  apex2011
                  I tried updating to 2.05.1, same issue unfortunately.
                  • apex2011undefined
                    apex2011
                    I had a spare BLTouch so I just tried installing it with new wiring in hopes that was the issue, it wasn't. I must be doing something wrong or missing something but I can't seem to find what it is.
                      Phaedrux Moderator @dc42
                      @dc42 said in Z Probe Trigger Height G30 S-1 height changing every probe:
                      Let us know how you get on. I notice that you are currently losing about 0.0025mm every other probe attempt, which at the 400 microsteps/mm you are using is 1 microstep. This gives me an idea about what may be happening.
                      I'm not sure what else to check for. Perhaps DC42 has an idea?
