Trigger wifi reconnect during long print
  • I thought this problem was gone after one of the recent updates, but it just returned about halfway through as 20 hour print.
    What are the options to get the duet wifi to attempt to reconnect while printing.
    Running Linux BTW
    Thanks
    Cory
    Assuming you are running recent versions of RRF and DuetWiFiServer, the Duet continuously tries to reconnect if it loses the connection.
    If for some reason it keeps failing to reconnect, then you could try resetting the wifi module (M552 S-1) followed by restarting it (M552 S1 assuming you run it in client mode). You could do this in a macro, commanded from a PanelDue or from a trigger.
  • It was updated to latest version end of November or December. It's been much better recently.
    Can this be done through USB?
    Wifi light is off, not blinking, just off
    @clytle374 said in Trigger wifi reconnect during long print:
    Yes, you can send those 2 commands via USB.
  • @clytle374 said in Trigger wifi reconnect during long print:
    You may be on 2.04, or one of the 2.05RC releases. Best to update to 2.05 release: https://github.com/dc42/RepRapFirmware/releases/tag/2.05
    @dc42 put in a lot of work to resolve the wifi disconnection issues. When you are next able to connect, please can you send M122 and post the response.
  • I'm back online, here's the version info
    RepRapFirmware for Duet 2 WiFi/Ethernet 2.05 (2019-12-13b1)
    Duet WiFi Server Version: 1.23
    Duet Web Control 2.0.4
    Can I run M122 while printing?
  • @clytle374 Yes, it should be okay to run M122 when printing!
  • @droftarts
    M122 output
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later
    Board ID: 08DGM-917DA-G4MSJ-6JKDA-3SN6N-KSRB9
    Used output buffers: 6 of 24 (16 max)
    Static ram: 25712
    Dynamic ram: 92584 of which 416 recycled
    Exception stack ram used: 512
    Never used ram: 11848
    Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,3800) IDLE(ready,160)
    Owned mutexes: WiFi(NETWORK)
    Last reset 09:57:05 ago, cause: reset button or watchdog
    Last software reset at 2019-12-30 07:03, reason: User, spinning module GCodes, available RAM 12088 bytes (slot 1)
    Error status: 12
    Free file entries: 9
    SD card longest block write time: 7.6ms, max retries 0
    MCU temperature: min 42.3, current 42.6, max 42.9
    Supply voltage: min 11.6, current 12.1, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 0: ok, SG min/max 0/395
    Driver 1: ok, SG min/max 0/415
    Driver 2: ok, SG min/max 0/414
    Driver 3: ok, SG min/max not available
    Date/time: 2020-01-08 12:35:31
    Slowest loop: 14.02ms; fastest: 0.07ms
    Hiccups: 0, FreeDm: 156, MinFreeDm: 108, MaxWait: 0ms
    === DDARing ===
    Scheduled moves: 724836, completed moves: 724801, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    Heater 0 is on, I-accum = 0.1
    Heater 1 is on, I-accum = 0.6
    Segments left: 1
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is doing "G1 F3600.000" in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 200.31ms; fastest: 0.08ms
    Responder states: HTTP(0) HTTP(0) HTTP(1) HTTP(0) FTP(0) Telnet(0) Telnet(0)
    HTTP sessions: 1 of 8
    - WiFi -
    Network state is running
    Failed messages: pending 0, notready 0, noresp 1
    WiFi firmware version 1.23
    WiFi MAC address cc:50:e3:0d:22:c1
    WiFi Vcc 3.35, reset reason Turned on by main processor
    WiFi flash size 4194304, free heap 22792
    WiFi IP address 192.168.0.13
    WiFi signal strength -51dBm, reconnections 0, sleep mode modem
    Socket states: 0 0 2 0 0 0 0 0
  • If I'm reading this properly I'm on the latest firmware.
    Thanks
    Cory
    Error status: 12
    Referring to Error_codes_and_software_reset_codes this means:
    0x04 Output buffer starvation
    0x08 Output stack overflow
    RRF 2.04 and 2.05 had changes to fix most instances of these. I've referred this thread to @dc42 to have a look at.
  • @droftarts
    My internet in the building with the printer is a special kind of horrible, the main DSL hasn't been much better. I've spent the last 2 days working on the system. Fixed DSL, I think. Ran ethernet to building and removing the cheap wifi booster out here.
    I've changed the wifi name and password in the config.g file on the duet. But it's still connecting to the old wifi. How do I get it to change over?
    NEVERMIND: That was way harder than it should be.
    Thanks
    Cory
