PrusaSlicer cannot upload to DWC 2.04/RRF 3
Any updates to this?> I have a brand new Duet3 setup and it is getting a 404 error when I try to upload from Slic3r. Is there a setup guide, do I need an API key? If so where do i find it?
None that I know of. There's nothing you can do to resolve this short of getting into the code and building your own, unless you know both code bases intimately I wouldn't recommend it.
On my Mac, the only way I can get slic3r to upload g-code is to have DWC opened in the background.
@William That is true with slic3r, at least on the Mac, but PrusaSlicer has fixed that issue. I can upload from PrusaSlicer without keeping an open connection in a browser.
I have Prusaslicer, on Mac, uploading direct to Duet 3 with latest firmware. Works as intended.
Are you using stand alone or SBC? I believe the issue doesn't occur with stand alone.
@chrishamm said in PrusaSlicer cannot upload to DWC 2.04/RRF 3:
I see no reason to send a PR to PrusaSlicer before that part is complete.
@chrishamm, while you interacting with Prusa, can you also ask to increase the PrusaSlicer's timeout for Duet's uploads? Last time I checked it was 10 secs which cause the upload to fail on large prints. A minute or two should be fine.
(my upload speed from DWC is ~200KB/s. Using RRF 2)
