    PrusaSlicer cannot upload to DWC 2.04/RRF 3
    Duet Web Control
    12
    27
    3.0k
    • Garfieldundefined
      Garfield
      Had a look at the network request from Prusa and it is GET /rr_connect?password=reprap&time=
      I'm not sure how this works - no username ??
      the js code shows async connect(hostname, username, password) - one of the three is missing.
      This is the text from syslog on the rPi for IP request
      Jan 11 18:14:11 duet3 DuetWebServer[403]:       Request starting HTTP/1.1 GET http://10.100.2.243/rr_connect?password=reprap&time=2020-01-11T18:14:11
      Jan 11 18:14:11 duet3 DuetWebServer[403]: #033[40m#033[32minfo#033[39m#033[22m#033[49m: Microsoft.AspNetCore.Hosting.Diagnostics[2]
      Jan 11 18:14:11 duet3 DuetWebServer[403]:       Request finished in 11.0556ms 404
      This is the response using hostname - no difference - the pi is reporting the target rr_connect as inaccessible or unavailable
      Jan 11 19:51:41 duet3 DuetWebServer[403]:       Request starting HTTP/1.1 GET http://duet3.local/rr_connect?password=reprap&time=2020-01-11T19:51:41
      Jan 11 19:51:41 duet3 DuetWebServer[403]: #033[40m#033[32minfo#033[39m#033[22m#033[49m: Microsoft.AspNetCore.Hosting.Diagnostics[2]
      Jan 11 19:51:41 duet3 DuetWebServer[403]:       Request finished in 6.801900000000001ms 404
      • chas2706undefined
        chas2706
        David, please ignore the part reporting Duet Wifi and RRF3. I have found the issue.
        In config.g I have set up a static ip but it is not actually the one in use!
        Using the correct ip address I can confirm that you can upload from prusaslicer to Duet wifi running RRF3.0.
        I think there is a problem though if you using Duet3 and raspberry pi.
          @Garfield, thanks for that. I have logged this issue at https://github.com/chrishamm/DuetSoftwareFramework/issues/99.
          dc42 created this issue in chrishamm/DuetSoftwareFramework
          closed Can't upload files from PrusaSlicer #99
          • chrishammundefined
            chrishamm administrators
            DSF uses a different HTTP API than RRF and it looks like PrusaSlicer does not support the new API yet. It may be worth getting back to this once authentification has been fully implemented in DSF. I see no reason to send a PR to PrusaSlicer before that part is complete.
            Duet software engineer
            • Armontroutundefined
              Armontrout
              Any updates to this?> I have a brand new Duet3 setup and it is getting a 404 error when I try to upload from Slic3r. Is there a setup guide, do I need an API key? If so where do i find it?
              • Garfieldundefined
                Garfield
                None that I know of. There's nothing you can do to resolve this short of getting into the code and building your own, unless you know both code bases intimately I wouldn't recommend it.
                • Williamundefined
                  William
                  On my Mac, the only way I can get slic3r to upload g-code is to have DWC opened in the background.
                  mendenmhundefined 1 Reply Last reply Reply Quote 0
                  • mendenmhundefined
                    mendenmh @William
                    @William That is true with slic3r, at least on the Mac, but PrusaSlicer has fixed that issue. I can upload from PrusaSlicer without keeping an open connection in a browser.
                    • Thaliosundefined
                      Thalios
                      I have Prusaslicer, on Mac, uploading direct to Duet 3 with latest firmware. Works as intended.
                      Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
                      Heavily modified Ender 3 Pro (Duet 3 6HC)
                      Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
                      CR-10S Pro V2 (Duet 3 Mini 5+)
                      and a bunch of SLA printers..
                      blt3dpundefined 1 Reply Last reply Reply Quote 0
                      • blt3dpundefined
                        blt3dp @Thalios
                        @Thalios
                        Are you using stand alone or SBC? I believe the issue doesn't occur with stand alone.
                        My 3D Printing YouTube Channel
                        Better Living Through 3D Printing
                        Follow me on Instagram and Twitter
                        Instagram
                        Twitter
                        • zaptaundefined
                          zapta @chrishamm
                          @chrishamm said in PrusaSlicer cannot upload to DWC 2.04/RRF 3:
                          @chrishamm, while you interacting with Prusa, can you also ask to increase the PrusaSlicer's timeout for Duet's uploads? Last time I checked it was 10 secs which cause the upload to fail on large prints. A minute or two should be fine.
                          (my upload speed from DWC is ~200KB/s. Using RRF 2)
