Hot end not working after upgrade to RR3
on rr2 everything the hotend functioned, and there is not heated bed, upgraded to RR3 and i i get an error when trying to print
Error: Temperature reading fault on heater 1: unknown temperature sensor channel ...
E0 is the hotend and e0_temp is the thermistor on a duet 2rr2 config.g
M140 H-1 ; disable heated bed
M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0CRR3 config.g
M140 H-1 ; disable heated bed (overrides default heater mapping)
M308 S0 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin e0temp
M950 H0 C"e0heat" T0 ; create nozzle heater output on e0heat and map it to sensor 0
M143 H0 S280 ; set temperature limit for heater 0 to 280C
M307 H0 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit; Fans
M106 P1 S1 H0 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C -
@dingo007 said in Hot end not working after upgrade to RR3:
you selefcted heater1 but you configured heater0
M307 H0 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limitH0 is the bed heater
You have to configure that for H1 -
This line, you define the tool to use heater 1 which doesn't exist
Try
M563 P0 D0 H0 F0 ; define tool 0
@blt3dp
Bad idea.... -
modified as suggested and still not functioning ....
M308 S0 P"e0temp" Y"thermistor" T100000 B4138 C7.06e-8 R4700 ; configure sensor 0 as thermistor on pin e0temp
M950 H1 C"e0heat" T0 ; create nozzle heater output on e0heat and map it to sensor 0
M143 H1 S280 ; set temperature limit for heater 0 to 280C
M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit; Fans
@DIY-O-Sphere still no joy after modifying the config
1/10/2020, 11:01:08 PM M292 P1
Printing paused at X0.0 Y0.0 Z0.0
1/10/2020, 11:01:06 PM Resume state saved
Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
1/10/2020, 11:01:01 PM Error: Temperature reading fault on heater 1: unknown temperature sensor channelwith config.g
M308 S1 P"e0temp" Y"thermistor" T100000 B4138 C7.06e-8 R4700 ; configure sensor 0 as thermistor on pin e0temp
change to T1.
it would be easier if you did this in the configurator.
@Veti that configurator is too confusing, probably why i got where i am... and it was generated in RR config
Nope no joy.... maybe RR3 was abad idea
1/10/2020, 11:07:15 PM Error: Temperature reading fault on heater 1: unknown temperature sensor channel
Resume state saved
Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater faultconfig.g
M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 0
What do you mean? He's was heater 0 as his hotend heater, his tool was set to use heater 1 all that I suggested was to tell the tool definition to use the correct heater.
I do suppose you could change everything to heater 1 as was done, I would have just changed that one line to heater 0 instead.
Looking at your current config, it should work.
Does this bother anyone else?? Current 2000.0c
@dingo007
did you reststart after changing the config? -
@Veti yes, i always restart after any edits.... even single character edits.
@dingo007
2000 means there is no thermistor on that connector also delete the Calso your thermistors values are incorrect.
@blt3dp
Noone else would understand why H0 is used for the tool.
To comply with conventions I think it's better not to do that. -
working RR2 config.g
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0Cnon-working RR3 config.g
M308 S0 P"e0temp" Y"thermistor" T100000 B4138 R4700 ; configure sensor 0 as thermistor on pin e0temp
M307 H0 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit; Tools
M563 P0 D0 F0 ; define tool 0add it this way
@Veti said in Hot end not working after upgrade to RR3:
sorry
M563 P0 D0 H0 F0 ; define tool 0seems there is a problem with the configurator.
