low motor torque
please post your new config.g again
; Configuration file for Duet WiFi (firmware version 2.03) ; executed by the firmware on start-up ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"MGN-Cube" ; set printer name M667 S1 ; select CoreXY mode ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes forwards X M569 P1 S0 ; physical drive 1 goes forwards Y M569 P2 S0 ; physical drive 2 goes forwards Z-L M569 P3 S0 ; physical drive 3 goes forwards Z-R M560 P4 S1 ; physical drive 4 goes forwards E M560 P5 S0 ; physical drive 5 goes forwards Z M584 X0 Y1 Z2:5 E3 ; two Z motors connected to driver outputs Z and E0 M671 X-60:360 Y150:150 S15 ; leadscrews at left (connected to Z) and right (connected to E1) (of X axis) M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X200.00 Y200.00 Z4266.67 E420.00 ; set steps/mm M566 X900.00 Y900.00 Z12 E120.00 ; set jerk (mm/min) M203 X6000.00 Y6000.00 Z90 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z50 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z1600 E800 I30 ; set motor currents (mA) and motor idle factor in percent M84 S5 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis min M208 X300 Y300 Z365 S0 ; set axis max ; Endstops M574 X1 Y1 S1 ; set active high endstops M574 Z1 S2 ; set endstop controlled by probe ; Z-Probe M558 P1 H5 F120 T6000 ; set Z probe type to IR-Probe and the dive height + speed G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X0:280 Y5:300 S80 ; define mesh grid ; Heaters M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M305 P0 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T50 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom Configuration
by the drives you have four times M569 after that you use M560 this is wrong and should be M569
ohhh, I overlooked that. Thanks
Edit: now the reversing of the motor works! -
@SIam Good Spot
