    DUET3/RRF3 config-override.g empty
    Firmware installation
    • tobias_munichundefined
      tobias_munich
      my setup is
      DUET3, current RRF3 Firmware release , RPi with the DUET3D-Image.
      Issue:
      whenever i do a M500 run I am getting an empty config-override.g like below.
      My old PID stettings are disappeard. Is this a bug or a feature?
      ; config-override.g file generated in response to M500 at 2020-01-11 09:44
      ; Heater model parameters
      M307 H0 A C D S V B0
      M307 H1 A C D S V B0
      ; Workplace coordinates
      regards Tobias
      Hypercube-Evolution, Dual-Z, Nimble v2, Orion Piezo
      Duet3, DuetWifi, Raspberry Pi 4, 7 inch HDMI Display, Panel-Due
      Firmware: RepRapFirmware for Duet 3 MB6HC 'always the latest release'
      • SIamundefined
        SIam
        when you save your config (M500) did you load it bevore (M501) if not then is this the bug.
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        tobias_munichundefined 1 Reply Last reply Reply Quote 0
        • blt3dpundefined
          blt3dp
          I noticed this as well. If I run M500 after heater tuning, the values in configure-overrode are empty. I had to just translate the values into my own m307 and put them in config.g
          My 3D Printing YouTube Channel
          Better Living Through 3D Printing
          Follow me on Instagram and Twitter
          Instagram
          Twitter
            tobias_munich @SIam
            @SIam yes, I have M501 at the end of my config.g
              tobias_munich @blt3dp
              @blt3dp this is exactly the case
              • gtj0undefined
                gtj0
                There is a known bug with M500 not writing the heater parameters correctly.
                @dc42 and @chrishamm are supposed to be working on it.
                tobias_munichundefined 1 Reply Last reply Reply Quote 1
                  tobias_munich @gtj0
                  @gtj0 ok thanks for the info. didn’t found it.
                  regards Tobias
