    Duet Wifi mount for Ender 5
    • lui2004
      lui2004 last edited by
      Hi
      I have a new printer ( Ender 5 ) and i want to install the Duet Wifi but i cant finde a stl to my duet in to The ender 5 .
      Anyone have a stl file fir a mount ?
      Thanks in advance
      • lui2004
        Nothing ?
        Please some advise i want use duet wifi in my ender5
        • JamesM
          JamesM last edited by
          Did you look on thingiverse? I hopped on there and just typed duet ender 5 and found this one
          https://www.thingiverse.com/thing:3864082
          • DeadNewbie
            DeadNewbie last edited by
            A quick search on Thingiverse gave me these results
            https://www.thingiverse.com/thing:3342196
            https://www.thingiverse.com/thing:2673206
            Not sure on the space inside the Ender 5 electronics enclosur, but a simple adapter(it modifies the screw mountings) for the ender 3 case may fit for you but you will need to make sure the wifi antenna is outside the metal case.
            https://www.thingiverse.com/thing:3197999
            I went with the first one, but I will have mine laying flat.
            hope that helps
            DeadNewbie
            • dgrat
              dgrat last edited by
              Personally, I kept the metal case. Extended the opening for the SD-Card slot, moved the PSU by drilling some new screw holes and added a PCB holder to attach the Duet Wifi board.
