    PanelDue sharper icons
    PanelDue
    338
    • elias
      elias last edited by
      Hi, I've being working during the last few days on, what I want to believe is, improving how the PanelDue behaves an looks and I would like to share it with you before going for a Pull Request.
      I always have being annoyed about how some of the icons look when a dark theme is used, they have white artifacts on the borders, due o original transparency turned into different shapes of white.
      So I've edited every single image and sharpened (pixelated) all the borders. As I'm not good at graphic design, I have not being able to achieve the level I would like, but I thin the new set of icons I have come up with look much better, on average, fon all the different themes.
      Here is an example of how icons looked before and after my changes:
      P.S. As I was unable to find instructions on how to convert BMP icons to the indexed RGB565 format used on the source code, I also developed a very ruff but functional tool to do the conversion. If someone is interested on it I could share the source. It should work on any platform (WIndows, Linux, Mac), but I've only tested it on Linux.
      mrehorstdmd 1 Reply Last reply Reply Quote 3
      • mrehorstdmd
        mrehorstdmd @elias last edited by
        @elias I like it!
          Looks good! How does is look using the light theme?
          • elias
            Here are some photos of the light theme, the first one is using the original icon set and the second one is using my modified icon set.
            As you can see, here the icons show up some pixelation but it may be a good compromise for the improvement on the dark themes.
            Thank you very much for your feedback.
            • A Former User
              A Former User last edited by
              /me loves the new pixelated icons
              /me hates antialiasing on tft screens
              /me will be able to use (finally) dark theme properly
                dc42 administrators @elias last edited by
                @elias said in PanelDue sharper icons:
                Looks great! Please submit your PR.
                • elias
                  Thank you!
                  My PR is up now.
                  • elias
                    Hi @dc42, I just remembered about this PR, have you had any time to take a look to it? Do you need me to do something else?
                      I think it may be a while yet before the PanelDue firmware is revisted. Currently the focus is on RRF3.
                      elias 1 Reply Last reply Reply Quote 0
                      • elias
                        elias @Phaedrux last edited by
                        Ok, thank you @Phaedrux!
