Mesh bed leveling - probe says it can't reach the position
  • Hi all,
    I've been trying to setup mesh bed leveling on my duet2 for half a day now and I can't get it to probe the last row no matter what I do. I suspect I'm making some simple mistake so if someone would look at my config, I'd appreciate it.
    config.g
    ; generated by RepRapFirmware Configuration Tool v2.1.2 on Tue Nov 19 2019 11:51:11 GMT+1100 (Australian Eastern Daylight Time)
    G90                                         ; send absolute coordinates...
    M83                                         ; ...but relative extruder moves
    M550 P"HEVO"                                ; set printer name
    M667 S1                                     ; select CoreXY mode
    M552 S1                                     ; enable network
    M586 P0 S1                                  ; enable HTTP
    M586 P1 S1                                  ; enable FTP
    M586 P2 S0                                  ; disable Telnet
    M569 P0 S1                                  ; physical drive 0 goes forwards
    M569 P1 S1                                  ; physical drive 1 goes forwards
    M569 P2 S1                                  ; physical drive 2 goes forwards
    M569 P3 S1                                  ; physical drive 3 goes forwards
    M584 X0 Y1 Z2:4 E3                          ; set the second E to be Z2
    M671 X437.0:-39 Y0:0 S4  ; Set the Z motor relative locations
    M350 X16 Y16 Z16 E16 I1                     ; configure microstepping with interpolation
    M92 X160.00 Y160.00 Z400.00 E409.00          ; set steps per mm
    M906 X800 Y800 Z800 E850 I30                ; set motor currents (mA) and motor idle factor in per cent
    M84 S30                                     ; Set idle timeout
    ; Speed - M556 and M203 in mm/m and M203 and M204 in mm/s
    M566 X500 Y500 Z60 E800     ; set maximum instantaneous speed changes (mm/min)
    M203 X30000 Y30000 Z600 E10000 ; set maximum speeds (mm/min)
    M201 X9000 Y9000 Z600 E10000        ; set accelerations (mm/s^2)
    M204 P800 T4000			; Set printing and travel accelerations
    ; FEEDRATE CONVERSIONS
    	; 20mm/s = F1200
    	; 70mm/s = F4200
    	; 120mm/s = F7200
    ; mm/s * 60 = mm/m
    ; mm/m / 60 = mm/s
    M208 X0 Y-49 Z0 S1                            ; set axis minima
    M208 X366 Y358 Z360 S0                      ; set axis maxima
    M574 X1 Y1 S3                               ; set endstops controlled by motor stall detection
    M574 Z1 S2                                  ; set endstops controlled by probe
    M307 H3 A-1 C-1 D-1                         ; disable heater on PWM channel for BLTouch
    M558 P9 H5 F250 T12000                      ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X58 Y-38 Z2.28                       ; set Z probe trigger value, offset
    M305 P0 T100000 B3950 R4700                 ; set thermistor + ADC parameters for heater 0
    M143 H0 S120                                ; set temperature limit for heater 0 to 120C
    M305 P1 T100000 B4725 C7.060000e-8 R4700    ; set thermistor + ADC parameters for heater 1
    M143 H1 S300                                ; set temperature limit for heater 1 to 280C
    M106 P0 S0 I0 F500 H-1                      ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S1 I0 F500 H1 T45                   ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M106 P2 S1 I0 F500 H1 T45                     ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M563 P0 D0 H1 F0                            ; define tool 0
    G10 P0 X0 Y0 Z0                             ; set tool 0 axis offsets
    G10 P0 R0 S0                                ; set initial tool 0 active and standby temperatures to 0C
    ; 11 - MISCELLANEOUS
    M501                                               	; Load saved parameters from non-volatile memory
    T0                                                 	; Select first tool
    The mesh bed macro I'm using to run mesh bed leveling
    G28 X ;home x
    G28 Y ;home y
    G28 Z ; home Z last
    M557 X58:394 Y-38:320 S40 ; sets the X and Y Grid dimensions with a spacing of 40.
    G29 S0 ; Run probing sequence as defined in M557 above and save height map to SD.
    M374 ; Save the height map explicitly.
    G1 F12000 X5 Y5 ; move the carriage back to
    bed.g for if its important
    ; bed.g
    ; generated by RepRapFirmware Configuration Tool v2.1.2 on Tue Nov 19 2019 11:51:10 GMT+1100 (Australian Eastern Daylight Time)
    G28 ;home
    ; this is the probe locations, not the nozzles.
    ; consider the probe offsets.
    ; ignores endstops.
    G30 P0 X58.0 Y152 H0 Z-99999
    G30 P1 X366.0 Y152.0 H0 Z-99999 S2
    G28 Z ; home Z again to help with bed sag.
    G29 S1; loads the height map
    I can't see a problem with those files. I would expect the first row to be at Y=-38 and the last at Y=282, which should both be reachable by a probe with a Y offset of -38.
    After running mesh probing, please run the following commands without parameters to check that the values set correspond to the ones in config.g and your macro: M208, M557, G31.
  • Output of M208
    Axis limits X0.0:366.0, Y-49.0:358.0, Z0.0:360.0
    M557
    Grid: X58.0:394.0, Y-38.0:358.0, radius -1.0, X spacing 40.0, Y spacing 40.0, 90 points
    G31
    Current reading 0, threshold 500, trigger height 2.28, offsets X58.0 Y-38.0
    I posted the wrong meshbedlevel.g file, I had been changing it while trying to make it work. The one that is causing errors is:
    G28 X ;home x
    G28 Y ;home y
    G28 Z ; home Z last
    M557 X58:394 Y-38:358 S40 ; sets the X and Y Grid dimensions with a spacing of 40.
    G1 F12000 X5 Y5 ; move the carriage back to the start
    The errors in the console are:
    M98 P"0:/macros/MeshLevel.g"
    Warning: Skipping grid point (378.0, 322.0) because Z probe cannot reach it
    Warning: Skipping grid point (338.0, 322.0) because Z probe cannot reach it
    Warning: Skipping grid point (298.0, 322.0) because Z probe cannot reach it
    Warning: Skipping grid point (258.0, 322.0) because Z probe cannot reach it
    Warning: Skipping grid point (218.0, 322.0) because Z probe cannot reach it
    Warning: Skipping grid point (178.0, 322.0) because Z probe cannot reach it
    Warning: Skipping grid point (138.0, 322.0) because Z probe cannot reach it
    Warning: Skipping grid point (98.0, 322.0) because Z probe cannot reach it
    Warning: Skipping grid point (58.0, 322.0) because Z probe cannot reach it
    What I am trying to achieve is that the probes last probe row will be along a nozzle position of Y358 which I understand should have the probe at Y320. Y358 is the maximum Y position before the carriage will collide with the frame.
    The M557 coordinates give the bed position to be probed. As you have an offset Z probe, the nozzle Y position will be 38mm higher than the Y bed coordinate to be probed. So the highest Y coordinate you can probe is 38mm less than the max Y specified in your M208 command, so 320. That explains the messages when your M557 command goes up to Y358 and it tries to probe at Y322.
  • @dc42 said in Mesh bed leveling - probe says it can't reach the position:
    Hi David,
    Would it be possible you could have a look at my similar thread regarding mesh leveling on Printbite with the IR probe?
    I asked a question on what's working or not, and it would be handy to know before logging into Paypal...
  • @dc42 Right, thanks. I guess I still don't get how I can have the probe probe at the back of the print bed.
    With the maxima set to Y358 using M308, the highest value I can have with M557 for Y is Y320.
    If I adjust the maxima for the Y axis to Y396 so that M557 will accept Y358, I assume this will let the carriage crash into the frame as it can't go that far.
    The photo below has the probe in the position of the row I want to probe so it can physically reach.
