    Pin Naming Duet 2
    • andornotundefined
      andornot
      Is there list of pin names for the duet 2 for use with the latest firmware? I am struggling to find the pin names for the pt100 daughter board and thermocouple daughter board.
      SpatialOne custom delta printer, upgrading to print PEEK, PEKK & Ultem
      • mloidlundefined
        mloidl
        see https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names_for_Duet_2_WiFi_Ethernet
          droftarts administrators
          @andornot It's these:
          // SPI CS
          spi.cs1
          spi.cs2
          spi.cs3
          spi.cs4
          spi.cs5, duex.cs5, exp.50
          spi.cs6, duex.cs6, exp.9
          spi.cs7, duex.cs7, exp.14
          spi.cs8, duex.cs8, exp.19
          If you use the rrf config tool, you can get exemplar code by filling in the Heaters in the I/O mapping tab.
          andornotundefined 1 Reply Last reply Reply Quote 0
          • andornotundefined
            andornot @droftarts
            @droftarts thanks
