No G-Code output/report (a bug?)
  • Hi all,
    I'm experimenting no reports from launching G-Code commands (from G-Code console) that will produce an output when used without parameters.
    This is so frustrating especially when you, for example, have to run a PID tuning procedure (M303) and the results are not shown.
    How to fix this problem?
    Thank you!
    My setup
    Web Interface Version: 1.22.6
    Electronics: Duet Ethernet 1.02 or later + DueX2
  • Moderator
    @3Dreamer Update your firmware. Reporting has been added to many gcodes over time. Though with M303 tuning, the results are made active, and you see the results by sending M307 H[heater number]. If you want to see it as an M307 command, send M500 to save the config-override.g file in sys, open it, and copy out the M307 command.
