Duet 3 + SBC Connection Issues
  • Running into a connection problem when connected to an SBC
    @chrishamm & @gtj0 have been helping me quite a lot with this (last several posts on this thread):
    https://forum.duet3d.com/topic/11777/duet-3-and-jetson-nano/71?_=1579111810551
    (I'm starting a new thread to get more exposure since that thread is getting quite long, and now that my issue seems to be not unique to the Jetson Nano)
    The Problem:
    I can connect to the Duet via DWC (thermistors and endstops read correctly), but I can't send gcode commands to the Duet (console just hangs forever.)
    I've tried this with 3 different SBC configurations with the same result:
    1). Jetson Nano (initially)
    2). RPi running Raspbian (to rule out any problem with the Jetson)
    3). RPi with DuetPi (to rule out any problem with Rasbian)
    DSF installed without issues in all cases.
    What I have tried:
    1). Ensuring correct TransferReadyPin & adjusting SPI frequency in /opt/dsf/conf/config.json (SPI frequency is currently set to 2MHz)
    2). trying the above SBC configurations
    3). Confirming ribbon cable is connected correctly
    4). Swapping to a different ribbon cable
    Searching for a cause:
    1). Monitoring in Debug mode yields:
    jpomo@jpomo-desktop:~$ sudo /opt/dsf/bin/DuetControlServer
    Duet Control Server v1.2.3.0
    Written by Christian Hammacher for Duet3D
    Licensed under the terms of the GNU Public License Version 3
    [info] Settings loaded
    [info] Environment initialized
    [debug] Lost connection to Duet
       System.OperationCanceledException: Board is not available (no header)
       at DuetControlServer.SPI.DataTransfer.ExchangeHeader() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 965
       at DuetControlServer.SPI.DataTransfer.PerformFullTransfer(Boolean mustSucceed) in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 154
    [error] Duet is not available
    Possibly Helpful:
    1). stopping duetcontrolserver via terminal causes a popup in DWC that reads "Operation failed (Reason: Transport endpoint in not connected)" In this case I tried to send M122
    General Info:
    • Duet 3 V1.0
    • RRF 3.0 (lastest stable)
    • DSF on all SBC configs updated through terminal, "sudo apt-get update" etc.
    My Config.g generated by the configuration tool (note: my Duet's SD card contains only the sys folder, is this correct?)
    ; generated by RepRapFirmware Configuration Tool v2.1.5 on Thu Jan 09 2020 15:58:52 GMT-0700 (Mountain Standard Time)
    G90                                                              ; send absolute coordinates...
    M83                                                              ; ...but relative extruder moves
    M550 P"Duet 3"                                                   ; set printer name
    M667 S1                                                          ; select CoreXY mode
    M569 P0.0 S1                                                     ; physical drive 0.0 goes forwards
    M569 P0.2 S1                                                     ; physical drive 0.2 goes forwards
    M569 P0.1 S1                                                     ; physical drive 0.1 goes forwards
    M569 P0.5 S1                                                     ; physical drive 0.5 goes forwards
    M569 P0.3 S1                                                     ; physical drive 0.3 goes forwards
    M569 P0.4 S1                                                     ; physical drive 0.4 goes forwards
    M584 X0.0 Y0.2 Z0.1 E0.5:0.3:0.4                                 ; set drive mapping
    M350 X16 Y16 Z16 E16:16:16 I1                                    ; configure microstepping with interpolation
    M92 X100.00 Y100.00 Z1600.00 E409.00:409.00:100.00               ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00                ; set maximum instantaneous speed changes (mm/min)
    M203 X30000.00 Y30000.00 Z1200.00 E300000.00:300000.00:300000.00 ; set maximum speeds (mm/min)
    M201 X6000.00 Y6000.00 Z400.00 E2500.00:2500.00:500.00           ; set accelerations (mm/s^2)
    M906 X1400 Y1400 Z1000 E1000:1000:400 I30                        ; set motor currents (mA) and motor idle factor in per cent
    M84 S120                                                         ; Set idle timeout
    M208 X-35 Y-49 Z0 S1                                             ; set axis minima
    M208 X328.5 Y243 Z300 S0                                         ; set axis maxima
    M574 X1 S0 P"io6.in"                                             ; configure active-low endstop for low end on X via pin io6.in
    M574 Y1 S0 P"io7.in"                                             ; configure active-low endstop for low end on Y via pin io7.in
    M574 Z1 S1 P"io8.in"                                             ; configure active-high endstop for low end on Z via pin io8.in
    M558 P5 C"io5.in" H5 F120 T6000                                  ; set Z probe type to switch and the dive height + speeds
    G31 P500 X0 Y0 Z2.5                                              ; set Z probe trigger value, offset and trigger height
    M557 X-20:215 Y-34:195 S20                                       ; define mesh grid
    M308 S0 P"temp0" Y"thermistor" T100000 B4138                     ; configure sensor 0 as thermistor on pin temp0
    M950 H0 C"out0" T0                                               ; create bed heater output on out0 and map it to sensor 0
    M143 H0 S210                                                     ; set temperature limit for heater 0 to 210C
    M307 H0 B1 S1.00                                                 ; enable bang-bang mode for the bed heater and set PWM limit
    M140 H0                                                          ; map heated bed to heater 0
    M308 S1 P"temp1" Y"thermistor" T100000 B4725                     ; configure sensor 1 as thermistor on pin temp1
    M950 H1 C"out1" T1                                               ; create nozzle heater output on out1 and map it to sensor 1
    M143 H1 S300                                                     ; set temperature limit for heater 1 to 300C
    M307 H1 B0 S1.00                                                 ; disable bang-bang mode for the nozzle heater and set PWM limit
    M308 S2 P"temp2" Y"thermistor" T100000 B4725                     ; configure sensor 2 as thermistor on pin temp2
    M950 H2 C"out2" T2                                               ; create nozzle heater output on out2 and map it to sensor 2
    M143 H2 S300                                                     ; set temperature limit for heater 2 to 300C
    M307 H2 B0 S1.00                                                 ; disable bang-bang mode for the nozzle heater and set PWM limit
    M950 F0 C"out4" Q500                                             ; create fan 0 on pin out4 and set its frequency
    M106 P0 S0 H-1                                                   ; set fan 0 value. Thermostatic control is turned off
    M950 F1 C"out5" Q500                                             ; create fan 1 on pin out5 and set its frequency
    M106 P1 S0 H-1                                                   ; set fan 1 value. Thermostatic control is turned off
    M950 F2 C"out7" Q500                                             ; create fan 2 on pin out7 and set its frequency
    M106 P2 S1 H1 T45                                                ; set fan 2 value. Thermostatic control is turned on
    M950 F3 C"out8" Q500                                             ; create fan 3 on pin out8 and set its frequency
    M106 P3 S1 H2 T45                                                ; set fan 3 value. Thermostatic control is turned on
    M563 P0 S"L-Hemera" D0 H1 F0                                     ; define tool 0
    G10 P0 X0 Y0 Z0                                                  ; set tool 0 axis offsets
    G10 P0 R0 S0                                                     ; set initial tool 0 active and standby temperatures to 0C
    M563 P1 S"R-Hemera" D1 H2 F1                                     ; define tool 1
    G10 P1 X0 Y0 Z0                                                  ; set tool 1 axis offsets
    G10 P1 R0 S0                                                     ; set initial tool 1 active and standby temperatures to 0C
    M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"               ; set voltage thresholds and actions to run on power loss
    Any help is appreciated!
  • @jpomo10 Can you connect the Duet3's USB port to a computer (even the SBC) and get an M122 dump?
    I doubt an M122 dump would reveal anything new - as mentioned in the other thread, I think the main reason why this isn't working is because the Jetson Nano cannot communicate with the Duet 3 over SPI (hence the "no header" error message).
    If DCS is able to connect from your Raspberry Pi, please share the debug log. To get it, do this on the Pi:
    sudo systemctl stop duetcontrolserver
    sudo /opt/dsf/bin/DuetControlServer --log-level debug
    Also make sure there is no microSD card in the Duet 3.
  • Actually, I was looking for
    === Linux interface ===
    State: 0, failed transfers: 0
    Last transfer: 26ms ago
    RX/TX seq numbers: 22864/301
    SPI underruns 0, overruns 0
    Number of disconnects: 0
    Buffer RX/TX: 0/0-0
    from the M122.
    BUT I think that you hit it with the SDCard. If there's a /sys/config.g file on it, the Duet3 will operate in standalone mode.
  • This post is deleted!
  • What do you mean....
    You have all sys files on the sd-Card?
    are you having a physical card in your duet3 board?
    If you work with an SBC you should not have an SD Card inserted in your duet-board.
    If so, please take it out and try again...
  • @chrishamm
    pi@raspberrypi:~ $ sudo systemctl stop duetcontrolserver
    pi@raspberrypi:~ $ sudo /opt/dsf/bin/DuetControlServer --log-level debug
    [warn] RepRapFirmware got a bad header checksum
    [info] Connection to Duet established
    [info] IPC socket created at /var/run/dsf/dcs.sock
    [debug] IPC#2: Got new UNIX connection, checking mode...
    [debug] IPC#2: Subscription processor registered
    [debug] IPC#3: Got new UNIX connection, checking mode...
    [debug] IPC#3: Command processor added
    [debug] IPC#3: Received command ResolvePath
  • @tobias_munich
    I mean... the SD card would probably explain it. I see what I missed in the documentation now. Thanks for pointing it out.
    @gtj0 @chrishamm
    Thank you for your help on this, aswell! I'm glad it was simple, but I'm sorry to take us around in circles.
    Still not working on the Jetson, but I'll adjust SPI frequency as you suggested and see if I can get anywhere.
  • @jpomo10 always a pleasure 👍
