    Sending gcode commands to the duet
    • Shaqour
      Shaqour last edited by
      Hi
      I have duet3d and i wish to send gcode commands to the duet while its connected through the serial port.
      I need to send commands using matlab. From my knowladge, i can use it to send data over the serial port. However, i am not sure if the duet can directly accept the gcode commands from matlab when its connected through the usb.
      • gtj0
        gtj0 last edited by
        Yes it can.
        • Danal
          Danal last edited by Danal
          Connect Matlab's TX wire to Duet 3 6HC io0.in. No specific configuration is required (just don't assign io0 to any other use). If I recall 115200 baud, 8,N,1. If that doesn't' work, try a couple of other typical 'fast' baud rates.
          3.3V TTL SERIAL
          If those words don't already mean something to you, ask here...
          • A Former User
            A Former User last edited by
            I believe the default configuration for the uart on IO0 is 57k6 and cheksums enabled.
            Use M575 P1 S0 to disable cheksums if needed.
              dc42 administrators @Shaqour last edited by
              @Shaqour said in Sending gcode commands to the duet:
              If you can get MATLAB to generate Gcode commands and then send them to USB then the Duet will execute them.
              • shenouda13
                shenouda13 last edited by
                Hi all,
                I am new to the duet. I have connected a duet3D Mini 5+ to a raspberry pi 4 with a usb cable. I am trying to send gcode commands to the duet through the serial package in python. I have a stepper motor connected to the duet. So i am trying to send a command to rotate it. when i run the python script in the image below it just stops at line 6 (ser.write) and it doesn't execute the subsequent lines.
                Am I missing something?
                I would really appreciate your help on how to do it.
                thanks
                jay_s_uk 1 Reply Last reply Reply Quote 0
                • jay_s_uk
                  jay_s_uk @shenouda13 last edited by
                  @marco13 you've already started your own topic. please don't spam others (especially old ones)
