    Water-cooling tube adapter
    344
    • piperswundefined
      pipersw
      Some of you know where I can found :
      • G1/4 8mm to 3mm ID tube adapter
      • or 8mm to 3mm ID tube adapter
      • y splitter for 3mm ID tube
      • or 8mm to 2 way 3mm splitter
      In Europe if possible.
      Have you some parameters for a 10K temperature sensor for the water temperature ?
      infiniteloopundefined 1 Reply Last reply Reply Quote 0
      • piperswundefined
        pipersw
        It's like pneumatic connector ?
        • infiniteloopundefined
          infiniteloop @pipersw
          @pipersw Guess you have a water cooling block with pneumatic connectors? Then, you can use these adapters from E3D on the other end:
          Water-cooling barbed adapter kit
          Which brings you to an inner diameter of 5mm. From there on, you will need additional adapters and Y splitters - you can easily find these if you look out for fish tank accessories. Another source could be the water cooling stuff for PCs - quite costly, but they have some interesting couplings and other fancy parts…
          • Nuramoriundefined
            Nuramori
            I use colder brand medical disconnects which allowed me to spec the sizes you mentioned on either side of the disconnect. Also allows me to quickly manage the cooling loop without mess.
            If interested I can list the products I used.
            fmaundefined 1 Reply Last reply Reply Quote 0
            • fmaundefined
              fma @Nuramori
              @Nuramori said in Water-cooling tube adapter:
              I am!
              Frédéric
              • piperswundefined
                pipersw
                My tube are
                ID 8mm OD 11mm
                ID 3mm OD 5mm
                Dougal1957undefined 1 Reply Last reply Reply Quote 0
                • Dougal1957undefined
                  Dougal1957 @pipersw
                  @pipersw Have a look at these guys (UK Based and if you have trouble getting them to ship to you drop me a msg and I'll see what I can do for you there less than 5kM from me)
                  Hose fittings you can search their site for all sorts of stuff like this.
                  HTH
                  Doug
                  • piperswundefined
                    pipersw
                    Found : koolance FIT-V03
                    text alternatif
