    Duet 3 windows driver issue
    • adarshsimonundefined
      adarshsimon
      Re: Duet 3 + RRF3 : bad M999
      I had recently purchased two duet 3 boards . Both are not being detected by windows similar to the above thread (duet drivers do not work) . I have kept one of the boards without any changes and have updated the firmware on the other board using BOSSA. The problem persists and i have no idea why. I want to run the duet in standalone mode.I have tried release 3.0 and release 3.01 beta 1. Thanks in advance for any help. Capture.JPG
        adarshsimon
        Hello, found the solution. I had to manually select the driver from a list of available drivers . No idea why
          droftarts administrators @adarshsimon
          @adarshsimon said in Duet 3 windows driver issue:
          The connection guide says you may have to do this https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s5
          adarshsimonundefined 2 Replies Last reply Reply Quote 0
            adarshsimon @droftarts
            @droftarts yes, my bad.
              @droftarts The solution mentioned in the guide didn't exactly work for me. I had to go to
              "Update Drive Software -> Browse Computer for Software ->List of Device driver on my Computer -> Ports (COM & LPT) -> (manufacturer) Escher3D -> Alligator 3D Printer Control electronics".
                dc42 administrators @adarshsimon
                If you are using the latest Windows driver, then Duet 3 should appear in that list.
