    Long simulation time = fun guaranteed
    3D Printing General Chat
    851
    • Nxt-1undefined
      Nxt-1
      You know it's going to fun when the simulation alone takes 1,5h to do 🙂
      Duet3D and delta printer enthousiast. Buildlog
      Looking for Duet3D configuration support, check out Nxt-3D
        What was the print time determined by simulation? Simulation is typically around 60 times faster than printing.
        Nxt-1undefined 1 Reply Last reply Reply Quote 0
        • Nxt-1undefined
          Nxt-1 @dc42
          @dc42 38h13m30s so in this instance more like 30x
          • eitenundefined
            eiten
            What will it be?
            • Nxt-1undefined
              Nxt-1 @eiten
              @eiten said in Long simulation time = fun guaranteed:
              What will it be?
              It will be 1/6th of a mold for an epoxy granite pour I plan to do.
              A Former User? eitenundefined 2 Replies Last reply Reply Quote 0
              • DaBitundefined
                DaBit
                Offtopic: Sure about that? I used an MDF mold to cast the epoxy concrete gantry of my CNC mill, and the 30mm thick outer shell was barely stiff enough for 90kg of the stuff. Compacting the stuff exerts quite a bit of force on the mold. Also, with MDF you have smooth walls as a bonus, and with the bendable MDF you can create curves.
                • A Former User?
                  A Former User @Nxt-1
                  @Nxt-1 said in Long simulation time = fun guaranteed:
                  epoxy granite pour
                  colour me, intrigued, I'm sticking around for the update!
                  • DocTruckerundefined
                    DocTrucker
                    Hope you're not suffering the same problem as me or that build could be more like 47hrs!
                    https://forum.duet3d.com/topic/13407/simulation-has-become-inaccurate?_=1579639007249
                    • Nxt-1undefined
                      Nxt-1 @DaBit
                      @DaBit said in Long simulation time = fun guaranteed:
                      The bottom will be MDF, the parts I am printing have fillets (technically could do without if needed) and are not just a square shape. So fabricating the mould out of MDF only would be beyond my skills. Also, I plan to use at most 30kg.
                      • eitenundefined
                        eiten @Nxt-1
                        @Nxt-1 Sounds interesting. Please post results!
                        • A Former User?
                          A Former User
                          Maybe you have considered it already, but if you put a box around the print and pack the outside with sand before casting the epoxy granite inside the mold you'll have a lot of external support (thats the theory at least:)
                          Nxt-1undefined 1 Reply Last reply Reply Quote 1
                          • Nxt-1undefined
                            Nxt-1 @A Former User
                            @bearer said in Long simulation time = fun guaranteed:
                            This is actually very clever, I had not thought of this. Should I run into strength problems, I will definitely go look into this.
                            Since the topic of the epoxy cast has gained some interest here, I will start a dedicated thread.
                            A Former User? 1 Reply Last reply Reply Quote 1
                            • A Former User?
                              I haven't tried it but seen similar solution applied to similar problem. One aspect could be the exothermic reaction of the resin softening the print as well. If I ever get around to trying something similar I'd use my green sand and let the sand/clay dry thoroughly before casting for optimal external support.
                              • botundefined
                                bot
                                I've had simulations take like 5 hours, stop complaining 😛 (super high detail 5 day print)
                                *not actually a robot
                                • Nxt-1undefined
                                  Nxt-1 @bot
                                  @bot Hehe, nice
