Hemera settings for Reprap Firmware?
@droftarts said in Hemera settings for Reprap Firmware?:
@Eran898 said in Hemera settings for Reprap Firmware?:
M587 S"aaaa" P"bbbbbbbb" ; Configure access point. You can delete this line once connected
You should delete this line from your config.g, as it gets written to the Wifi module each time config.g is run. Not ideal for flash memory! See: https://duet3d.dozuki.com/Wiki/Gcode#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
Important! Do not use M587 within config.g. As well as being a security hazard, writing the access point parameters to WiFi chip every time you start the Duet may eventually wear out the flash memory. Also, the wifi module does not get enabled until the end of running config.g. It is better to use a macro to send M587 (source: https://forum.duet3d.com/post/42798)
Thanks for the info didn't knew that!.
So no one using the hemera on direct? haha.
Please if someone using it would be great just to see what numbers you are using
