    V2 Pinda without using thermistor?
    • UnderDoneSushiundefined
      UnderDoneSushi
      Would using this replacement V2 Pinda probe from PrintedSolid work plug and play with the duet since it is a 5V probe?
      Since I am not on RRF3 and still on RRF2 I would just leave the thermistor wire out of the plug and use it directly on the Z probe pins? Then when upgrading later down the road to RRF3 I could just use the thermistor and adjust the config accordingly?
      https://www.printedsolid.com/products/pinda-2-probe-replacement
      -Ian
        droftarts administrators @UnderDoneSushi
        @UnderDoneSushi You should be able to use the PINDA probe without the thermistor in RRF2, and it's supported with the thermistor in RRF3. See these threads about how to wire it up and configure in RRF2:
        https://forum.duet3d.com/topic/9045/pinda-v2-probe-wiring
        https://forum.duet3d.com/topic/11838/z-probe-input-signal
        https://forum.duet3d.com/topic/11866/pinda-z-probe-configuration
        If you can report back if this works, I'll add it to the wiki.
