    XY Motors on Duex5
    • smoki3
      smoki3 last edited by smoki3
      Does it matter if I connect the X and Y Motor of my corexy to my Duex5 instead of the duet2wifi or is there no difference in the timings and speed of communication?
      I also use stall detection on these axes.
      I know for example that for the endstops there was a difference in the latency between the duex and duet2.
      From wiring perspective I can save alot of time if this will work without any disadvantage
        It makes no difference whether you use the Duet or DueX motor connections.
        smoki3 1 Reply Last reply Reply Quote 0
        • smoki3
          smoki3 @dc42 last edited by
          @dc42 said in XY Motors on Duex5:
          Ok cool. Does it matter if I connect the Z probe to Duex5?
            dc42 administrators @smoki3 last edited by
            @smoki3 said in XY Motors on Duex5:
            Yes. The endstop inputs on DueX5 have higher latency. So I recommend that you connect the output from the Z probe to the Duet.
