    refresh save reboot message errors.
    56
    • Nuramori
      Nuramori last edited by
      I'm not sure why I'm getting the messages I am in the following:
      I understand the heater messages are warnings that I will always get, but why twice on reboot?
      I also get the "Response too long, see Console" but there's never anything there that gives a clue to the cause.
      Any input would be great. Below is my Config.g
      ; Configuration file for Duet3 (firmware version 3.0 RC2)
      ; --------------- Pin/connection Mapping Legend -------------------
      ; out0 - Bed heater
      ; out1 - Extruder 1 heater
      ; out2
      ; out3
      ; out4 - Radiator cooling fan - WC heatsink
      ; out5
      ; out6
      ; out7
      ; out8 - Parts cooler on printhead
      ; out9 - Duet board cooling fan
      ; out4.tach - Radiator cooling fan rpm wire - WC heatsink
      ; out5.tach
      ; out6.tach
      ; io0.in
      ; io1.in - X min active low endstop switch
      ; io2.in - Y max active low endstop switch
      ; io3.in - Z probe type to bltouch - DEPRECATED
      ; io4.in - Z probe type to PIEZO
      ; io5.in - Emergency stop switch
      ; io6.in
      ; io7.in
      ; io8.in
      ; io0.out
      ; io1.out
      ; io2.out
      ; io3.out - GPIO port 0 on IO3, servo mode - BLTouch Z-Probe
      ; io4.out
      ; io5.out
      ; io6.out
      ; io7.out
      ; io8.out
      ; servo, out10 (only on v0.5, not on v0.6)
      ; pson
      ; spi.cs0
      ; spi.cs1
      ; spi.cs2
      ; spi.cs3
      ; temp0 - Bed Thermistor
      ; temp1 - Extruder Thermistor (PT1000)
      ; temp2 - RPi Thermistor (PT1000)
      ; temp3
      ; mcu-temp - MCU sensor
      G4 P2000 ; Hold your Horses.
      G21 ; Set units to Millimeters
      M550 P"DUET3" ; set printer name
      M584 X0.3 Y0.2 Z0.0:0.1:0.4 E0.5 ; set drive mapping to each axis
      M669 K1 ; Select CoreXY mode - New format
      M552 S1 ; enable network
      M552 P192.168.3.120 ; Static IP Address
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0.0 S0 ; physical drive 0 goes backwards - Z Axis Left (1)
      M569 P0.1 S0 ; physical drive 1 goes backwards - Z Axis Right Back (2)
      M569 P0.2 S0 ; physical drive 2 goes backwards - Y Axis
      M569 P0.3 S0 ; physical drive 3 goes backwards - X Axis
      M569 P0.4 S0 ; physical drive 4 goes backwards - Z Axis Right Front (3)
      M569 P0.5 S1 ; physical drive 5 goes forwards - Extruder 1
      ; Set up three Z-axis location
      M671 X-52.5:377.5:377.5 Y162.5:282.5:42.5 S5 ; leadscrews at 1 - left, 2 - rear right and 3 - front right
      M92 X200.00 Y200.00 Z400.00 E1800 ; set steps per mm
      M350 X16 Y16 Z16 E16 I1 ; configure micro-stepping with interpolation
      M566 X1000.00 Y1000.00 Z400.00 E240.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X24000.00 Y24000.00 Z2000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X10000.00 Y10000.00 Z400.00 E800.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in percent*100
      M572 D0 S0.074 ; Set pressure advance
      M84 S30 ; Set idle timeout
      M208 X320 Y320 Z350 S0 ; set axis maxima
      M574 X1 S1 P"io1.in" ; X min active high endstop switch
      M574 Y2 S1 P"io2.in" ; Y max active high endstop switch
      ; Z-Probe - BLTouch - DEPRECATED
      ; M574 Z1 S2 ; set endstops controlled by probe
      ; M558 P9 C"^io3.in" H3 F60000 T10000 ; set Z probe type to bltouch and the dive height + speeds (bltouch NEEDS pullup)
      ; G31 P100 X28.5 Y-5 Z2.35 ; set Z probe trigger value, offset and trigger height
      ; Z-Probe - PIEZO
      M558 P8 C"io4.in" H5 F2000 T20000 ; set Z probe type to PIEZO and the dive height + speeds
      G31 P100 X0 Y0 Z-0.1 ; set Z probe trigger value, offset and trigger height
      ; G30 ; Probe Z
      ; Configure Heaters and Sensors
      M308 S0 P"temp0" Y"thermistor" A"Bed Temp" T100000 B3950 ; Configure bed temperature sensor
      M308 S1 P"temp1" Y"pt1000" A"Extruder 1 Temp" ; Configure extruder 1 temperature sensor - PT1000 sensor
      M308 S2 P"mcu-temp" Y"mcu-temp" A"Duet Board" ; Configure MCU sensor
      ; M308 S4 P"temp2" Y"pt1000" A"RPI" R2200 ; pt1000 temp sensor for the raspberry pi
      ; Define Sensors and Fans
      M950 H0 C"out0" T0 ; Define heater 0 (bed heater) - bed_heat pin and Temp Sensor 0
      M950 H1 C"out1" T1 ; Define heater 1 (hot-end E0) to use the "e0_heat" pin and Temp Sensor 1
      M950 F0 C"out8" Q100 ; Define Fan_0 for use - Parts Cooler on Printhead - 4010 fan
      M950 F1 C"!out4+^out4.tach" Q25000 ; Define Fan_1 for use - Radiator cooling - WC heatsink. - PWM fan
      M950 F2 C"out9" Q25000 ; Define Fan_2 for use - Duet board cooling fan
      ; M950 S0 C"io3.out" ; Define GPIO port 0 on IO3, servo mode - BLTouch Z-Probe - DEPRECATED
      M106 P0 S0 ; set fan 0. Parts Cooler on Printhead
      M106 P1 T25:40 H2 ; Set fan 1. Manages Radiator fan for water-cooled loop.
      M106 P2 T30:45 H2 ; Set fan 2. Manages Duet board fan.
      ;Set PID values
      M307 H0 A177.4 C351.6 D1.0 V23.3 B0 ; disable bang-bang mode for the bed heater and set PWM limit
      M307 H1 A862.2 C371.3 D5.7 V23.3 B0 ; disable bang-bang mode for the extruder heater and set PWM limit
      M563 P0 S"Extruder 1" D0 H1 F0 ; define tool 0. Fan 0 operates with an active hot-end
      G10 P0 X0 Y0 Z0 R0 S0 ; set tool 0 axis offsets active and standby temperatures to 0C
      ; Emergency Stop
      M574 S1 P"^!io5.in" ; Define Emergency endstop - emergency stop switch condition
      M581 P"io5.in" T0 ; Define action to be taken with activation of emergency stop switch
      T0 ; select first tool
      M501 ; Store parameters
      • A Former User
        A Former User last edited by
        have you got a config-override.g as well?
        • Nuramori
          sigh. Yeah....... It's days like this that cause me to binge on Hallmark movies and just die in a weeping puddle.
          Ok, so the double message is answered. I'm still not sure what the "response too long" is tied to.
          deckingman dc42 2 Replies Last reply Reply Quote 0
          • deckingman
            deckingman @Nuramori last edited by
            @Nuramori The "response too long" just means that the message is too long to fit in a pop-up window. That's why the rest of the message is "see console" 🙂
            Also for info, I never use a config override file because sooner or later, having configuration settings in two different places will bite you (as you have discovered).
            • Nuramori
              aaahhh, I thought response too long was referring to time, as in response to a command is taking too long.
              heh. oopsie. Thanks for the info.
              • deckingman
                @Nuramori I can see how that could easily be confusing. Perhaps the message would be better if it was just "See console for response" or some such.
                  dc42 administrators @Nuramori last edited by dc42
                  @Nuramori said in refresh save reboot message errors.:
                  Each M307 command generated that message, if appropriate.
                  "Response too long" is usually seen only when you run M122, so I am not sure why it is being generated.
                  • deckingman
                    deckingman @dc42 last edited by
                    @dc42 said in refresh save reboot message errors.:
                    I'm 99% sure that I've seen that message for responses other than M122 and had to refer to the console. I can't off hand recall the specific instances and my printer is in bits right now so I'm unable to test.
                      dc42 administrators @deckingman last edited by dc42
                      @deckingman said in refresh save reboot message errors.:
                      I am fairly sure that DWC decides whether to display the response in a popup or issue this message depending on how many newline characters the message contains. I can display really long M409 responses in the popup, but not shorter multi-line responses, such as to M574 with no parameters.
                      Nuramori 1 Reply Last reply Reply Quote 0
                      • Nuramori
                        Nuramori @dc42 last edited by
                        @dc42 looking back at the console, the only message that was there was a theee line message about the endstops and their status.
