Duet2wifi water-cooled
  • Hi
    I wish water-cooling the Duet2wifi.
    I want to keep working and without fan the board at 70deg ambiant temperature.
    I have four steppers at 1.4A, 24V 40W hotend and 24V 400W bed.
    So I need to cool only the TMC and bed mosfet ?
    Waterblock have to be put on top of the components or on the bottom pcb ?
    I could use thermal adhesive for fixing the blocks on pcb, but I don't know if it's electrical conductive.
    Have you some pictures of duet2wifi bottom ?
  • I guess needing to cook the TMC is a typo for cool...
    In any case I'd say that approach is ill adviced from may different aspects.
    ALL the components will have their lifespan shortened if operated at elevated temperatures, not only the ones generating a lot of heat. It may not matter much but it is a factor to consider.
    Mounting the water block with thermal adhesive is less secure than regular fastners like screws, also the bottom of the PCB will expand and contract at different rates than the water block so this further emphasises the need for screw mounting.
    It would be FAR BETTER to mount the duet and power supply outside of whatever enclose is kept at 70 degrees. (C i presume?)
  • as @bearer said, move the duet outside of the enclosure, change the wires, lengthen them and you are golden ... if you really can't do it, give up on water and go with mineral oil, dump the whole thing in mineral oil and cool the mineral oil tank with a coil that has cold water running trough it if you areadly have water cooling set up
  • Moderator
    @smece said in Duet2wifi water-cooled:
    @pipersw and please post pictures!
  • As @smece said, move the duet outside of the enclosure if possible. This addresses the root cause.
  • I cannot put the electronic outside I prefer to have all inside the printer and no wire outside the enclosure.
  • @pipersw how do you plan on cooling the water? If you can stick a radiator + fan on the outside you probably fit the Duet in the same space instead. If you plan on having the water cooling all on the inside then you're just adding heat to the closed system.
  • @pipersw said in Duet2wifi water-cooled:
    In general (at least for the stepper drivers) you need to cool components from the bottom. Their thermal via's are on the bottom of the components and in direct contact with the heavy copper planes in the pcb to distribute the heat. So it also makes sense to cool the whole underside of the pcb if at all possible.
    I have found that often thermal compounds are at least a bad conductor, sometimes even a good one. So definitely check your material. On the topic of attaching your waterblock, keep in mind that the bottom surface of the Duet has many protrusions from component legs sticking trough the board. I would be surprised if you can fit a decent sized water block to the bottom with any amount of thermal contact.
    The picture below (samelessly taken from somewhere else on the forum) illustrates my point.
    Cannot or don't want to?
    Prefer it all you want, it's NOT a good idea.
    You came here requesting help, if you don't like the advice being offered what is the point in asking?
  • @CaLviNx said in Duet2wifi water-cooled:
    Why are you so agressive ?
    The enclosure is in my living room, so noise is important, and I don't want the duet outside, only the radiator.
    In commercial temperature, the components are operating up to 70C ambiant, and 85C in industrial temperature.
    ...that moment you realize that the cooling of the radiator will have to match the cooling of the duet in any case...
    (also have you even read https://duet3d.dozuki.com/Wiki/Mounting_and_cooling_the_board#Section_Cooling )
    edit:
    Their specifications are still listed at 25C, exceed that and expect to derate everything including power handling and MTBF.
    but you will have more noise from the fan on the water grill than you will have from duet, on room temperature with nice heatsinks stuck to the bottom there's no need for force cooling (I do have some "will start to blow fan if the box temp goes over 40c" but the fan never turns on)
  • Moderator
    If you mount the duet outside vertically with enough air vents it likely won't need a fan at all unless you're running 2a+ current.
