mesh bed compensation not applying correct corrections
@necrorat said in mesh bed compensation not applying correct corrections:
01/02/2020, 15:16:27 M98 P"0:/macros/probe test"
does that macro do this?
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height -
@Veti ive wrote it as this to probe 3 times per spot:
G1 Z10
G30 S-1
G1 Z10
G30 S-1
G1 Z10
G30 S-1 -
so have just run it again and i am getting quite a large variance now in the region of 0.11mm is this a mechanical issue? the machine is set up on linear rails and i have ensured that they are as square and parallel as possible
G1 Z10
G30 S-1
G1 Z10
G30 S-1
G1 Z10
G30 S-1that determines repeatability, but does not determine z probe trigger height as you do not determine z=0 before probing as described in the above linked document
@Veti so do i have to go though the full calibration procedure for each point that i probe on the bed?
@necrorat
do one at the point where the lines where ok and one where the lines where not ok -
@Veti so just did a test over 5 point and theses are the results :
2.064
2.068
2.066
2.059
2.046 -
thats a lot different than your original trigger height of 2.31
@Veti i have been tinkering with the frame and alignment all day. gonna probe the bed one last time then try another print
Sry to bring up that old post again.
@necrorat Did you find a solution or the reason why the meshbed compensation didn't apply?
I have the same issue.
