    mesh bed compensation not applying correct corrections
    2.7k
      Where are those locations in relation to the heightmap?
        I see you're using the BLTouch. You can attempt to get a bit more accuracy and repeatability out of it by modifying your M558 a bit.
        M558 P9 H5 F60 T6000 A10 R0.75 S0.003 B1
        Slower probe speed, with repeated attempts if 2 consecutive probes don't match to within a tighter tolerance. Probing will take longer because of the slower dive height and it will do at least 2 probes per point. But you will be far less likely to get outliers.
        necroratundefined 1 Reply Last reply Reply Quote 0
        • necroratundefined
          necrorat @Phaedrux
          @Phaedrux so 1 is the rear right of the height map and 3 is the front centre on the height map. sweet thanks for the tip ill change that out and give it a try probably wont be till tomorrow till ill get to try it now though.
          • Vetiundefined
            Veti
            can you measure the z trigger heigh at different positions?
            it is possible that you have different trigger heights based on position.
            • necroratundefined
              necrorat @Veti
              @Veti so i measured the z trigger height and it didn't vary by more than 0.005mm at each of the 9 points i measured at, it did vary from point to point but thats kinda the point of bed levelling isn't it ?
              • Vetiundefined
                Veti @necrorat
                @necrorat said in mesh bed compensation not applying correct corrections:
                no the z trigger height has to be constant across the entire bed otherwise you have the effects that you are seeing.
                to clarify i am not refereing the the result of a G30 but the valude of of Z for G31 when calibrating it.
                • necroratundefined
                  necrorat @Veti
                  @Veti just ran though a 3x3 grid to check and i am consistently getting 2.31 for the trigger height
                  01/02/2020, 15:16:27 M98 P"0:/macros/probe test"
                  Current reading 0, threshold 25, trigger height 2.31, offsets X-29.5 Y11.4
                  • Vetiundefined
                    Veti @necrorat
                    does that macro do this?
                    https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                    • necroratundefined
                      necrorat @Veti
                      @Veti ive wrote it as this to probe 3 times per spot:
                      G1 Z10
                      G30 S-1
                      G1 Z10
                      G30 S-1
                      G1 Z10
                      G30 S-1
                      • necroratundefined
                        necrorat
                        so have just run it again and i am getting quite a large variance now in the region of 0.11mm is this a mechanical issue? the machine is set up on linear rails and i have ensured that they are as square and parallel as possible
                        • Vetiundefined
                          Veti @necrorat
                          G1 Z10
                          G30 S-1
                          G1 Z10
                          G30 S-1
                          G1 Z10
                          G30 S-1
                          that determines repeatability, but does not determine z probe trigger height as you do not determine z=0 before probing as described in the above linked document
                          • necroratundefined
                            necrorat @Veti
                            @Veti so do i have to go though the full calibration procedure for each point that i probe on the bed?
                            • Vetiundefined
                              Veti @necrorat
                              @necrorat
                              do one at the point where the lines where ok and one where the lines where not ok
                              • necroratundefined
                                necrorat @Veti
                                @Veti so just did a test over 5 point and theses are the results :
                                2.064
                                2.068
                                2.066
                                2.059
                                2.046
                                • Vetiundefined
                                  Veti
                                  thats a lot different than your original trigger height of 2.31
                                  • necroratundefined
                                    necrorat @Veti
                                    @Veti i have been tinkering with the frame and alignment all day. gonna probe the bed one last time then try another print
                                    • Stuffiundefined
                                      Stuffi
                                      Sry to bring up that old post again.
                                      @necrorat Did you find a solution or the reason why the meshbed compensation didn't apply?
                                      I have the same issue.
