Duet Wifi Hangs up after booting about 1 out of 5 times
  • Is this a hardware or firmware issue? I bought the board about a year ago and only now setting it up.
    I first flashed it to v3 and I got lucky if it boots up 1 out of 10 times I reboot it. I downgraded it to v 2.04 or 05 I think and I get 1 out of 5 success on boot.
    I have a paneldue 4.3" hooked up to it.
    When it runs it runs beautifully for hours and hours though. My issue only happens on reboot. I'm thinking its part of the external comms that stops working because when its homing for example, It continues its tasks even when the PanelDue commands are not being accepted and due is not getting info back from Duet.
    Network data is gone too on the Chrome explorer when this happens.
    I suspect there is something in your config file that sometimes makes your board hang up. As your first line in config.g you may want to add "M111 P3 S1", hook up a computer to your board, and check what messages you get in a serial console (or rather what codes are processed line by line).
  • Cool thanks. I was wondering the same. Because when I had the stock config on v2 before adding the Bltouch to it was ok on bootup,
  • Moderator
    @gta18 Of course, burning out the driver might have affected something else! https://forum.duet3d.com/topic/14109/burnt-driver-3-on-duet-wifi
    Try booting without the SD card. If that works reliably, post your config.g so we can check it over. Reformatting the SD card and putting a fresh copy of your files on may help too.
  • @droftarts config.g
    Lol... It hanged up before I burnt it. 🙂
  • @gta18 said in Duet Wifi Hangs up after booting about 1 out of 5 times:
    @droftarts config.g
    I attached my config.g
  • Im noticing that after it connects to wifi that's the time it hangs. I have put the M111 P3 s1 and here's the result before it looses comms. Could it be I have incompatible wifi firmware flashed?
    I don't know of a way to read the WiFi module firmware release... so the only path is to upgrade it to match your regular firmware.
    You can enter M115 at the console to find your main firmware release. You can then decide to research the matching WiFi, or just upgrade everything.
    On a Duet WiFi, I'd recommend going to 2.05 and the matching WiFi and DWC.
  • Moderator
    @Danal said in Duet Wifi Hangs up after booting about 1 out of 5 times:
    You can enter M155 at the console to find your main firmware release
    M115
  • Moderator
    Sending M122 will produce the Diagnostic report. In that there will be the RepRapFirmware version:
    m122
    SENDING:M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04RC1 running on Duet WiFi 1.0 or 1.01
    and in the last section under '- WiFi -' will be the WiFi firmware version:
    WiFi firmware version 1.23
    Please post a full M122 report.
  • This post is deleted!
  • Sorry for the late reply. But here's the m122 report screenshot.
    thanks
    https://www.amazon.com/photos/shared/lXQNAkoJSMO044FHVWApOw.PGAgU00Nab0LtoQoQrNJba
  • You'll need to use a usb cable and a terminal to capture the full output.
  • I thought I was missing something just seeing it so short. Thanks for the advise. Here's the report on v3
    Attempting connection at \\.\COM5...
      Testing plaintext communication protocol...
    READ: ok
      Connected to machine!
    SENT: T0
    READ: ok
    SENT: M105
    READ: ok T:2000.0 /120.0 T0:2000.0 /120.0 B:25.5 /0.0
    READ: Error: Temperature reading fault on heater 1: unknown sensor
    SENT: m122
    READ: === Diagnostics ===
    READ: RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet WiFi 1.02 or later
    READ: Board ID: 08DJM-9178L-L2MSD-6J9DL-3SD6T-KVDYP
    READ: Used output buffers: 1 of 24 (6 max)
    READ: === RTOS ===
    READ: Static ram: 30516
    READ: Dynamic ram: 91592 of which 28 recycled
    READ: Exception stack ram used: 256
    READ: Never used ram: 8680
    READ: Tasks: NETWORK(ready,1676) HEAT(blocked,920) MAIN(running,4124) IDLE(ready,156)
    READ: Owned mutexes:
    READ: === Platform ===
    READ: Last reset 00:00:13 ago, cause: power up
    READ: Last software reset at 2020-02-07 17:53, reason: User, spinning module GCodes, available RAM 8180 bytes (slot 2)
    READ: Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
    READ: Error status: 0
    READ: Free file entries: 10
    READ: SD card 0 detected, interface speed: 20.0MBytes/sec
    READ: SD card longest block write time: 0.0ms, max retries 0
    READ: MCU temperature: min 30.7, current 34.0, max 34.1
    READ: Supply voltage: min 1.2, current 1.6, max 1.6, under voltage events: 0, over voltage events: 0, power good: no
    READ: Driver 0: ok, SG min/max not available
    READ: Driver 1: ok, SG min/max not available
    READ: Driver 2: ok, SG min/max not available
    READ: Driver 3: ok, SG min/max not available
    READ: Driver 4: ok, SG min/max not available
    READ: Date/time: 1970-01-01 00:00:00
    READ: Cache data hit count 17245507
    READ: Slowest loop: 1.67ms; fastest: 0.07ms
    READ: I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0
    READ: === Move ===
    READ: Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
    READ: Bed compensation in use: none, comp offset 0.000
    READ: === MainDDARing ===
    READ: Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    READ: === AuxDDARing ===
    READ: === Heat ===
    READ: Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
    READ: === GCodes ===
    READ: Segments left: 0
    READ: Stack records: 1 allocated, 0 in use
    READ: Movement lock held by null
    READ: http is idle in state(s) 0
    READ: telnet is idle in state(s) 0
    READ: file is idle in state(s) 0
    READ: serial is ready with "m122" in state(s) 0
    READ: aux is idle in state(s) 0
    READ: daemon is idle in state(s) 0
    READ: queue is idle in state(s) 0
    READ: autopause is idle in state(s) 0
    READ: Code queue is empty.
    READ: === Network ===
    READ: Slowest loop: 1.26ms; fastest: 0.00ms
    READ: Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
    READ: HTTP sessions: 0 of 8
    READ: - WiFi -
    READ: Network state is changing mode
    READ: WiFi module is trying to connect
    READ: Failed messages: pending 0, notready 0, noresp 0
    READ: WiFi firmware version 1.23
    READ: WiFi MAC address bc:dd:c2:57:ad:41
    READ: WiFi Vcc 3.47, reset reason Turned on by main processor
    READ: WiFi flash size 4194304, free heap 28104
    READ: Socket states: 0 0 0 0 0 0 0 0
    READ: ok
    SENT: M105
    READ: ok T:2000.0 /0.0 T0:2000.0 /0.0 B:25.5 /0.0
    SENT: M105
  • Flashed it to v2.05 with the same issues. Here's the report when on v2.05.
    READ: RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later
    READ: Used output buffers: 1 of 24 (3 max)
    READ: === RTOS ===
    READ: Static ram: 25712
    READ: Dynamic ram: 93116 of which 0 recycled
    READ: Exception stack ram used: 264
    READ: Never used ram: 11980
    READ: Tasks: NETWORK(ready,1664) HEAT(blocked,1324) MAIN(running,3824) IDLE(ready,160)
    READ: Last reset 00:00:14 ago, cause: power up
    READ: Last software reset at 2020-02-07 18:14, reason: User, spinning module GCodes, available RAM 11716 bytes (slot 3)
    READ: Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
    READ: MCU temperature: min 33.5, current 34.2, max 34.2
    READ: Supply voltage: min 1.2, current 1.2, max 1.6, under voltage events: 0, over voltage events: 0, power good: no
    READ: Cache data hit count 55012547
    READ: Slowest loop: 3.77ms; fastest: 0.05ms
    READ: === Move ===
    READ: Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
    READ: === DDARing ===
    READ: === Heat ===
    READ: Heater 1 is on, I-accum = 0.0
    READ: Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
    READ: - WiFi -
    READ: WiFi flash size 4194304, free heap 28176
    READ: ok
    READ: aux: M408 S0 R4
    SENT: M105
    READ: serial: M105
    READ: ok T:33.0 /0.0 T0:33.0 /0.0 B:27.1 /0.0
    SENT: M105
    READ: serial: M105
    READ: ok T:32.9 /0.0 T0:32.9 /0.0 B:27.1 /0.0
    SENT: M105
    READ: serial: M105
    READ: ok T:32.9 /0.0 T0:32.9 /0.0 B:27.0 /0.0
    READ: WiFi module is connected to access point BBB1, IP address 192.168.2.135
    READ: aux: M408 S1
    SENT: M105
    READ: serial: M105
    READ: ok T:32.8 /0.0 T0:32.8 /0.0 B:27.0 /0.0
    Disconnected.
  • My config.g on v3, e0temp pin stopped working. Temperature reads 2000. I flashed v2.05 back and e0temp works.
    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Feb 07 2020 13:37:35 GMT-0800 (Pacific Standard Time)
    M550 P"NogMM3"                                     ; set printer name
    M586 P1 S1                                         ; enable FTP
    M569 P0 S1                                         ; physical drive 0 goes forwards
    M569 P1 S1                                         ; physical drive 1 goes forwards
    M569 P2 S1                                         ; physical drive 2 goes forwards
    M569 P3 S0                                         ; physical drive 3 goes backwards
    M584 X0 Y1 Z2 E3                                   ; set drive mapping
    M350 X256 Y256 Z256 E256 I0                        ; configure microstepping without interpolation
    M92 X1280.00 Y1280.00 Z6800.00 E420.00             ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00            ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
    M906 X800 Y800 Z800 E800 I30                       ; set motor currents (mA) and motor idle factor in per cent
    M208 X230 Y260 Z200 S0                             ; set axis maxima
    M574 X1 S1 P"xstop"                                ; configure active-high endstop for low end on X via pin xstop
    M574 Y2 S1 P"ystop"                                ; configure active-high endstop for high end on Y via pin ystop
    M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
    M950 S0 C"exp.heater3"                             ; create servo pin 0 for BLTouch
    M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000      ; set Z probe type to bltouch and the dive height + speeds
    M558 H30                                           ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
    G31 P500 X-32 Y-26 Z3.3                            ; set Z probe trigger value, offset and trigger height
    M557 X15:230 Y15:260 S15                           ; define mesh grid
    M308 S0 P"bedtemp" Y"thermistor" T100000 B4092     ; configure sensor 0 as thermistor on pin bedtemp
    M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
    M308 S1 P"e0temp" Y"pt1000" R4700                  ; configure sensor 1 as PT1000 on pin e0temp
    M143 H1 S325                                       ; set temperature limit for heater 1 to 325C
    M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
    M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
    M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
    M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
    M501                                               ; load saved parameters from non-volatile memory
  • my Config.g on v2.05 where e0temp works for my extruder. Hopefully some simple fix to get v3 working.
    ; Configuration file for Duet WiFi (firmware version 2.00)
    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Jan 26 2020 07:53:26 GMT-0800 (Pacific Standard Time)
    M550 P"MendelMax3Nog"                    ; set printer name
    m111 p3 s1
    M586 P1 S0                               ; disable FTP
    M569 P4 S1                               ; physical drive 4 goes forwards
    M584 X0 Y1 Z2 E4                         ; set drive mapping
    M350 X64 Y64 Z64 E64 I0                  ; configure microstepping without interpolation
    M92 X320.00 Y320.00 Z1600.00 E1636     ; set steps per mm
    M208 X230 Y260 Z220 S0                   ; set axis maxima
    M574 X1 Y2 S1                            ; set active high endstops
    M574 Z1 S2                               ; set endstops controlled by probe
    M307 H3 A-1 C-1 D-1                      ; disable heater on PWM channel for BLTouch
    M558 P9 H5 F120 T6000                    ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X-33 Y-26 Z3.4              ; set Z probe trigger value, offset and trigger height
    M557 X15:270 Y15:260 S15                 ; defin0 mesh grid
    M305 P0 T100000 B4800 R4700              ; set thermistor + ADC parameters for heater 0
    M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
    M106 P0 S0 I0 F500 H-1                   ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S1 I0 F500 H1 T45                ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M563 P0 S"Volcano 0.8" D0 H1 F0          ; define tool 0
  • here's another m122 on v3
    M122
    Used output buffers: 3 of 24 (9 max)
    Static ram: 30516
    Dynamic ram: 91832 of which 0 recycled
    Exception stack ram used: 496
    Never used ram: 8228
    Tasks: NETWORK(ready,640) HEAT(blocked,816) MAIN(running,4100) IDLE(ready,156)
    Owned mutexes:
    Last reset 00:03:34 ago, cause: power up
    Last software reset time unknown, reason: User, spinning module GCodes, available RAM 8512 bytes (slot 0)
    Error status: 0
    SD card longest block write time: 20.7ms, max retries 0
    MCU temperature: min 31.9, current 33.5, max 33.9
    Supply voltage: min 23.3, current 24.8, max 25.2, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 0: standstill, SG min/max 58/138
    Driver 1: standstill, SG min/max 0/237
    Date/time: 2020-02-08 12:48:53
    Cache data hit count 567632536
    Slowest loop: 37.47ms; fastest: 0.09ms
    Hiccups: 274(0), FreeDm: 169, MinFreeDm: 163, MaxWait: 10023ms
    Bed compensation in use: mesh, comp offset 0.020
    === MainDDARing ===
    Scheduled moves: 25, completed moves: 25, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    === AuxDDARing ===
    Heater 0 is on, I-accum = 0.1
    Heater 1 is on, I-accum = 0.5
    Segments left: 0
    serial is idle in state(s) 0
    === Network ===
    Slowest loop: 73.70ms; fastest: 0.00ms
    HTTP sessions: 1 of 8
    - WiFi -
    Network state is running
    WiFi flash size 4194304, free heap 21656
    WiFi IP address 192.168.2.135
    WiFi signal strength -57dBm, reconnections 0, sleep mode modem
    Quite a lot of changes to config are needed when changing from RRF2 to RRF3. If your machine has no unusual features, It is simplest to use the online configurator to generate new files. Otherwise, see https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Summary_of_what_you_need_to_do_to_convert_your_configuration_and_other_files.
  • So I have got the v3 running successfully but still suffering from the random bootup hanging up as before in any version. Is there anything wrong with my config?
    Everything works now except random bootup issues.
    Were u able to see any problems with the m122 report I posted?
    Thanks
    @dc42 said in Duet Wifi Hangs up after booting about 1 out of 5 times:
  • Moderator
    I would check things like the power supply and the SD card. As in, perhaps you have flaky PSU, or the SD card is dying.
  • @Phaedrux I have used 3 sd cards and all have failures.
    Ill check power supply make sure my input voltage is stable at 24v during startup.
  • I checked power supply during bootup and its rock solid at 24.13 to 24.15v all the way according to my Fluke 789.
    Still experiencing bootup hang ups. 😞
