    Duet Wifi Hangs up after booting about 1 out of 5 times
    42
    2.0k
    • Danalundefined
      Danal @gta18
      @gta18 said in Duet Wifi Hangs up after booting about 1 out of 5 times:
      Could it be I have incompatible wifi firmware flashed?
      I don't know of a way to read the WiFi module firmware release... so the only path is to upgrade it to match your regular firmware.
      You can enter M115 at the console to find your main firmware release. You can then decide to research the matching WiFi, or just upgrade everything.
      On a Duet WiFi, I'd recommend going to 2.05 and the matching WiFi and DWC.
      Phaedruxundefined Dougal1957undefined 2 Replies Last reply Reply Quote 1
        Phaedrux Moderator @Danal
        @Danal said in Duet Wifi Hangs up after booting about 1 out of 5 times:
        You can enter M155 at the console to find your main firmware release
        M115
        • Danalundefined
          Danal @Phaedrux
          @Phaedrux said in Duet Wifi Hangs up after booting about 1 out of 5 times:
          M115
          Good catch. Edited.
            droftarts administrators
            Sending M122 will produce the Diagnostic report. In that there will be the RepRapFirmware version:
            m122
            SENDING:M122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04RC1 running on Duet WiFi 1.0 or 1.01
            and in the last section under '- WiFi -' will be the WiFi firmware version:
            WiFi firmware version 1.23
              Please post a full M122 report.
              • Dougal1957undefined
                Dougal1957 @Danal
                This post is deleted!
                • gta18undefined
                  gta18
                  Sorry for the late reply. But here's the m122 report screenshot.
                  thanks
                  https://www.amazon.com/photos/shared/lXQNAkoJSMO044FHVWApOw.PGAgU00Nab0LtoQoQrNJba
                    A Former User
                    You'll need to use a usb cable and a terminal to capture the full output.
                    • gta18undefined
                      gta18
                      I thought I was missing something just seeing it so short. Thanks for the advise. Here's the report on v3
                      Attempting connection at \\.\COM5...
                        Testing plaintext communication protocol...
                      READ: ok
                        Connected to machine!
                      SENT: T0
                      READ: ok
                      SENT: M105
                      READ: ok T:2000.0 /120.0 T0:2000.0 /120.0 B:25.5 /0.0
                      READ: Error: Temperature reading fault on heater 1: unknown sensor
                      SENT: m122
                      READ: === Diagnostics ===
                      READ: RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet WiFi 1.02 or later
                      READ: Board ID: 08DJM-9178L-L2MSD-6J9DL-3SD6T-KVDYP
                      READ: Used output buffers: 1 of 24 (6 max)
                      READ: === RTOS ===
                      READ: Static ram: 30516
                      READ: Dynamic ram: 91592 of which 28 recycled
                      READ: Exception stack ram used: 256
                      READ: Never used ram: 8680
                      READ: Tasks: NETWORK(ready,1676) HEAT(blocked,920) MAIN(running,4124) IDLE(ready,156)
                      READ: Owned mutexes:
                      READ: === Platform ===
                      READ: Last reset 00:00:13 ago, cause: power up
                      READ: Last software reset at 2020-02-07 17:53, reason: User, spinning module GCodes, available RAM 8180 bytes (slot 2)
                      READ: Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                      READ: Error status: 0
                      READ: Free file entries: 10
                      READ: SD card 0 detected, interface speed: 20.0MBytes/sec
                      READ: SD card longest block write time: 0.0ms, max retries 0
                      READ: MCU temperature: min 30.7, current 34.0, max 34.1
                      READ: Supply voltage: min 1.2, current 1.6, max 1.6, under voltage events: 0, over voltage events: 0, power good: no
                      READ: Driver 0: ok, SG min/max not available
                      READ: Driver 1: ok, SG min/max not available
                      READ: Driver 2: ok, SG min/max not available
                      READ: Driver 3: ok, SG min/max not available
                      READ: Driver 4: ok, SG min/max not available
                      READ: Date/time: 1970-01-01 00:00:00
                      READ: Cache data hit count 17245507
                      READ: Slowest loop: 1.67ms; fastest: 0.07ms
                      READ: I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0
                      READ: === Move ===
                      READ: Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                      READ: Bed compensation in use: none, comp offset 0.000
                      READ: === MainDDARing ===
                      READ: Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                      READ: === AuxDDARing ===
                      READ: === Heat ===
                      READ: Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
                      READ: === GCodes ===
                      READ: Segments left: 0
                      READ: Stack records: 1 allocated, 0 in use
                      READ: Movement lock held by null
                      READ: http is idle in state(s) 0
                      READ: telnet is idle in state(s) 0
                      READ: file is idle in state(s) 0
                      READ: serial is ready with "m122" in state(s) 0
                      READ: aux is idle in state(s) 0
                      READ: daemon is idle in state(s) 0
                      READ: queue is idle in state(s) 0
                      READ: autopause is idle in state(s) 0
                      READ: Code queue is empty.
                      READ: === Network ===
                      READ: Slowest loop: 1.26ms; fastest: 0.00ms
                      READ: Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                      READ: HTTP sessions: 0 of 8
                      READ: - WiFi -
                      READ: Network state is changing mode
                      READ: WiFi module is trying to connect
                      READ: Failed messages: pending 0, notready 0, noresp 0
                      READ: WiFi firmware version 1.23
                      READ: WiFi MAC address bc:dd:c2:57:ad:41
                      READ: WiFi Vcc 3.47, reset reason Turned on by main processor
                      READ: WiFi flash size 4194304, free heap 28104
                      READ: Socket states: 0 0 0 0 0 0 0 0
                      READ: ok
                      SENT: M105
                      READ: ok T:2000.0 /0.0 T0:2000.0 /0.0 B:25.5 /0.0
                      SENT: M105
                      • gta18undefined
                        gta18
                        Flashed it to v2.05 with the same issues. Here's the report when on v2.05.
                        READ: RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later
                        READ: Used output buffers: 1 of 24 (3 max)
                        READ: === RTOS ===
                        READ: Static ram: 25712
                        READ: Dynamic ram: 93116 of which 0 recycled
                        READ: Exception stack ram used: 264
                        READ: Never used ram: 11980
                        READ: Tasks: NETWORK(ready,1664) HEAT(blocked,1324) MAIN(running,3824) IDLE(ready,160)
                        READ: Last reset 00:00:14 ago, cause: power up
                        READ: Last software reset at 2020-02-07 18:14, reason: User, spinning module GCodes, available RAM 11716 bytes (slot 3)
                        READ: Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                        READ: MCU temperature: min 33.5, current 34.2, max 34.2
                        READ: Supply voltage: min 1.2, current 1.2, max 1.6, under voltage events: 0, over voltage events: 0, power good: no
                        READ: Cache data hit count 55012547
                        READ: Slowest loop: 3.77ms; fastest: 0.05ms
                        READ: === Move ===
                        READ: Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                        READ: === DDARing ===
                        READ: === Heat ===
                        READ: Heater 1 is on, I-accum = 0.0
                        READ: Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                        READ: - WiFi -
                        READ: WiFi flash size 4194304, free heap 28176
                        READ: ok
                        READ: aux: M408 S0 R4
                        SENT: M105
                        READ: serial: M105
                        READ: ok T:33.0 /0.0 T0:33.0 /0.0 B:27.1 /0.0
                        SENT: M105
                        READ: serial: M105
                        READ: ok T:32.9 /0.0 T0:32.9 /0.0 B:27.1 /0.0
                        SENT: M105
                        READ: serial: M105
                        READ: ok T:32.9 /0.0 T0:32.9 /0.0 B:27.0 /0.0
                        READ: WiFi module is connected to access point BBB1, IP address 192.168.2.135
                        READ: aux: M408 S1
                        SENT: M105
                        READ: serial: M105
                        READ: ok T:32.8 /0.0 T0:32.8 /0.0 B:27.0 /0.0
                        Disconnected.
                        • gta18undefined
                          gta18
                          My config.g on v3, e0temp pin stopped working. Temperature reads 2000. I flashed v2.05 back and e0temp works.
                          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Feb 07 2020 13:37:35 GMT-0800 (Pacific Standard Time)
                          G90                                                ; send absolute coordinates...
                          M83                                                ; ...but relative extruder moves
                          M550 P"NogMM3"                                     ; set printer name
                          M552 S1                                            ; enable network
                          M586 P0 S1                                         ; enable HTTP
                          M586 P1 S1                                         ; enable FTP
                          M586 P2 S0                                         ; disable Telnet
                          M569 P0 S1                                         ; physical drive 0 goes forwards
                          M569 P1 S1                                         ; physical drive 1 goes forwards
                          M569 P2 S1                                         ; physical drive 2 goes forwards
                          M569 P3 S0                                         ; physical drive 3 goes backwards
                          M584 X0 Y1 Z2 E3                                   ; set drive mapping
                          M350 X256 Y256 Z256 E256 I0                        ; configure microstepping without interpolation
                          M92 X1280.00 Y1280.00 Z6800.00 E420.00             ; set steps per mm
                          M566 X900.00 Y900.00 Z12.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
                          M203 X6000.00 Y6000.00 Z180.00 E1200.00            ; set maximum speeds (mm/min)
                          M201 X500.00 Y500.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
                          M906 X800 Y800 Z800 E800 I30                       ; set motor currents (mA) and motor idle factor in per cent
                          M84 S30                                            ; Set idle timeout
                          M208 X0 Y0 Z0 S1                                   ; set axis minima
                          M208 X230 Y260 Z200 S0                             ; set axis maxima
                          M574 X1 S1 P"xstop"                                ; configure active-high endstop for low end on X via pin xstop
                          M574 Y2 S1 P"ystop"                                ; configure active-high endstop for high end on Y via pin ystop
                          M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
                          M950 S0 C"exp.heater3"                             ; create servo pin 0 for BLTouch
                          M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000      ; set Z probe type to bltouch and the dive height + speeds
                          M558 H30                                           ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
                          G31 P500 X-32 Y-26 Z3.3                            ; set Z probe trigger value, offset and trigger height
                          M557 X15:230 Y15:260 S15                           ; define mesh grid
                          M308 S0 P"bedtemp" Y"thermistor" T100000 B4092     ; configure sensor 0 as thermistor on pin bedtemp
                          M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
                          M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
                          M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
                          M140 H0                                            ; map heated bed to heater 0
                          M308 S1 P"e0temp" Y"pt1000" R4700                  ; configure sensor 1 as PT1000 on pin e0temp
                          M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
                          M143 H1 S325                                       ; set temperature limit for heater 1 to 325C
                          M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                          M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
                          M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
                          M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
                          M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
                          M563 P0 D0 H1 F0                                   ; define tool 0
                          G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
                          G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
                          M501                                               ; load saved parameters from non-volatile memory
                          • gta18undefined
                            gta18
                            my Config.g on v2.05 where e0temp works for my extruder. Hopefully some simple fix to get v3 working.
                            ; Configuration file for Duet WiFi (firmware version 2.00)
                            ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Jan 26 2020 07:53:26 GMT-0800 (Pacific Standard Time)
                            M550 P"MendelMax3Nog"                    ; set printer name
                            m111 p3 s1
                            M586 P1 S0                               ; disable FTP
                            M569 P4 S1                               ; physical drive 4 goes forwards
                            M584 X0 Y1 Z2 E4                         ; set drive mapping
                            M350 X64 Y64 Z64 E64 I0                  ; configure microstepping without interpolation
                            M92 X320.00 Y320.00 Z1600.00 E1636     ; set steps per mm
                            M208 X230 Y260 Z220 S0                   ; set axis maxima
                            M574 X1 Y2 S1                            ; set active high endstops
                            M574 Z1 S2                               ; set endstops controlled by probe
                            M307 H3 A-1 C-1 D-1                      ; disable heater on PWM channel for BLTouch
                            M558 P9 H5 F120 T6000                    ; set Z probe type to bltouch and the dive height + speeds
                            G31 P500 X-33 Y-26 Z3.4              ; set Z probe trigger value, offset and trigger height
                            M557 X15:270 Y15:260 S15                 ; defin0 mesh grid
                            M305 P0 T100000 B4800 R4700              ; set thermistor + ADC parameters for heater 0
                            M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
                            M106 P0 S0 I0 F500 H-1                   ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                            M106 P1 S1 I0 F500 H1 T45                ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                            M563 P0 S"Volcano 0.8" D0 H1 F0          ; define tool 0
                            • gta18undefined
                              gta18
                              here's another m122 on v3
                              M122
                              Used output buffers: 3 of 24 (9 max)
                              Static ram: 30516
                              Dynamic ram: 91832 of which 0 recycled
                              Exception stack ram used: 496
                              Never used ram: 8228
                              Tasks: NETWORK(ready,640) HEAT(blocked,816) MAIN(running,4100) IDLE(ready,156)
                              Owned mutexes:
                              Last reset 00:03:34 ago, cause: power up
                              Last software reset time unknown, reason: User, spinning module GCodes, available RAM 8512 bytes (slot 0)
                              Error status: 0
                              SD card longest block write time: 20.7ms, max retries 0
                              MCU temperature: min 31.9, current 33.5, max 33.9
                              Supply voltage: min 23.3, current 24.8, max 25.2, under voltage events: 0, over voltage events: 0, power good: yes
                              Driver 0: standstill, SG min/max 58/138
                              Driver 1: standstill, SG min/max 0/237
                              Date/time: 2020-02-08 12:48:53
                              Cache data hit count 567632536
                              Slowest loop: 37.47ms; fastest: 0.09ms
                              Hiccups: 274(0), FreeDm: 169, MinFreeDm: 163, MaxWait: 10023ms
                              Bed compensation in use: mesh, comp offset 0.020
                              === MainDDARing ===
                              Scheduled moves: 25, completed moves: 25, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                              === AuxDDARing ===
                              Heater 0 is on, I-accum = 0.1
                              Heater 1 is on, I-accum = 0.5
                              Segments left: 0
                              serial is idle in state(s) 0
                              === Network ===
                              Slowest loop: 73.70ms; fastest: 0.00ms
                              HTTP sessions: 1 of 8
                              - WiFi -
                              Network state is running
                              WiFi flash size 4194304, free heap 21656
                              WiFi IP address 192.168.2.135
                              WiFi signal strength -57dBm, reconnections 0, sleep mode modem
                                dc42 administrators @gta18
                                Quite a lot of changes to config are needed when changing from RRF2 to RRF3. If your machine has no unusual features, It is simplest to use the online configurator to generate new files. Otherwise, see https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Summary_of_what_you_need_to_do_to_convert_your_configuration_and_other_files.
                                gta18undefined 1 Reply Last reply Reply Quote 0
                                • gta18undefined
                                  gta18 @dc42
                                  So I have got the v3 running successfully but still suffering from the random bootup hanging up as before in any version. Is there anything wrong with my config?
                                  Everything works now except random bootup issues.
                                  Were u able to see any problems with the m122 report I posted?
                                  Thanks
                                  @dc42 said in Duet Wifi Hangs up after booting about 1 out of 5 times:
                                    Phaedrux Moderator @gta18
                                    I would check things like the power supply and the SD card. As in, perhaps you have flaky PSU, or the SD card is dying.
                                    • gta18undefined
                                      gta18 @Phaedrux
                                      @Phaedrux I have used 3 sd cards and all have failures.
                                      Ill check power supply make sure my input voltage is stable at 24v during startup.
                                      • gta18undefined
                                        gta18
                                        I checked power supply during bootup and its rock solid at 24.13 to 24.15v all the way according to my Fluke 789.
                                        Still experiencing bootup hang ups. 😞
                                          droftarts administrators @gta18
                                          @gta18 After reading through this thread, it seems likely this is a hardware issue. To confirm, the main issue is now that the board fails to boot reliably every time? The problem of external comms stopping has been solved with firmware updates? Also, how is the board mounted? Is there any possibility of short circuiting the board to it's mounting location (metal enclosure/loose wiring)? Is the board clean, ie no metal filings that could cause shorts on the board (I'd give it a vacuum clean with a soft brush to make sure)? I couldn't see any obvious problems in the M122 reports you posted.
                                          Assuming the above is all fine, I'd guess there is a floating (ie unsoldered or poorly soldered) pin or faulty component somewhere on the board, and could be almost anything connected to the processor. Can you post clear pictures of top and bottom of the board, and particular around this area?
                                          Did any of the M111 reports happen during a freeze? Actually, I'd set M111 S1 to capture all debug info (P3 is just the webserver), though don't leave this on all the time as it can affect printing because of the volume of data sent to USB. Connect USB, and connect to the Duet as quickly as possible after power up, to see if you can catch it when it hangs. This may be able to determine what's causing the hang, and indicate where to look on the board, eg gets stuck waiting for SD card, or initialising Wifi module.
                                          • gta18undefined
                                            gta18 @droftarts
                                            @droftarts Ill check/do what u suggested when I get home tonight.
                                            This is the 2nd board from amazon and did the exact same hanging up.
                                            My board right now just sits on top of an MDF board with nothing below it.
                                            One sign that I see on the paneldue when it is about to hang is that the wifi connection pop up does not show up.
                                            100% of the time I'm able to hit home and the machine finishes the homing though, but one indication that it won't respond to any more commands is that after the homing procedure it does not update where the nozzle final location is (x45 y25,z7.8) for me.
                                            But when I get a successful bootup, I'm able to print for 10hours without any snag and print again and again, just don't reboot it.
                                            It seems like to me, that some part of the external comms of the board quits working or doesn't initialize properly, both wifi and serial.
