    Retract from specific tool if not selected
    79
    • CJ.BRAVO
      CJ.BRAVO last edited by
      I've got several tools(extruders) that have different steps from each other.
      I usually run my gcode file and press PAUSE which retracts:
      "G1 E-10 F3600 ; retract 10mm of filament"
      My issue is that each tool I'd like to have certain amount of retractions and speeds.
      Can I select specific tool to retract while in PAUSE?
      Let's say tool 1 is selected in the file thats running and it needs "E-100 F6000" and tool 2 which will need "E-500 F8000". I don't want to change the PAUSE file each time I have a different tool.
      Ideas?
      deckingman dc42 zerspaner_gerd 3 Replies Last reply Reply Quote 0
      • deckingman
        deckingman @CJ.BRAVO last edited by
        @CJ-BRAVO Why not use the tool change macro files https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Tool_change_files?
        • Danal
          Danal last edited by
          As mentioned, this is the very reason that tool change macros are separate per tool.
            dc42 administrators @CJ.BRAVO last edited by
            @CJ-BRAVO said in Retract from specific tool if not selected:
            Ideas?
            Use the conditional GCode facilities of RRF 3.01.
            CJ.BRAVO 1 Reply Last reply Reply Quote 0
            • CJ.BRAVO
              CJ.BRAVO @dc42 last edited by
              I using duet 2.
              RRF 3 is only for DUET 3, correct?
              • deckingman
                I using duet 2.
                No. (but in any case, you don't need RRF3 to use the tool change macros which, IMO Iis the easiest way to achieve what you want to do).
                • zerspaner_gerd
                  zerspaner_gerd @CJ.BRAVO last edited by
                  @deckingman said in Retract from specific tool if not selected:
                  No tool change macros are executed during the pause
                  • deckingman
                    deckingman @zerspaner_gerd last edited by
                    @zerspaner_gerd True. But using the tool change macros is a better way to achieve what he wants to do than using pause.
                    • CJ.BRAVO
                      CJ.BRAVO @deckingman last edited by
                      @deckingman
                      My initial issue is that I do want to pause the job and have a retraction - with any tool (which have different steps).
                      So does the tool change macro work? Maybe just I'll write a new pause macro?
                        Two solutions:
                        1. Use T-1 in the pause.g file to deselect the tool, so that it runs the tfree file. Then use T R1 in resume.g to reselect it.
                        2. Use RRF 3 with conditional GCode in pause.g.
                        • CJ.BRAVO
                          hmm..
                          I am leaning towards RRF3...
                          Where should I goto for some conditional GCode in RRF 3.01 lessons?
                            hmm..
                            https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands
                            • SteveYYC
                              SteveYYC last edited by SteveYYC
                              If you don't want to use conditional processing (or upgrade to RRF3):
                              You could set your firmware retract for the tool in the tool change macro (ie tpostn.g for tool n):
                              M207 S-10  F3600 ; retract 10 mm
                              then use G10/G11 firmware retracts in the pause command
                              G10 ; retract the filament by a tool-specific amount
