Problem reaching machine setting in the latest release
Hi!
I've started installation of my duet2 bought some months ago.
i followed instructions and installed the latest firmware and web software. When i'm now about to install endstops and all the other cables i can't see the "machine settings" only UI settings in the webpage.
I had saved a tab in the browser with the old web page and was able to see "machine settings" and also click it.
I really need to see the endstops indications, any help?
I also tried to revert the firmware to the "2" generation but got an
error reporting that duetcombinedIAP file was missing so it is not
possible to revert. -
Hi1
Thanks for answering!In Settings i have only "User Interface"
About says "Duet Web Control" 2.0.0-RC3 is that right? -
@stend said in Problem reaching machine setting in the latest release:
Hi1
About says "Duet Web Control" 2.0.0-RC3 is that right?That's very old. Try the 2.0.7 SD version from https://github.com/chrishamm/DuetWebControl/releases/tag/2.0.7.
!! working
Thanks for the very prompt reply.
Now first a cup of tea and then endstops
regards
/Sten -
If you do ever want to return to the previous 2.x firmware you can find that missing file along with the other firmware .bin files in the release.
