    Stepper motors not turning
    82
    • id104335409
      id104335409 last edited by
      Hi, I am not very good with electronics, but I made this coreXY printer and I am wiring the Duet2 WiFi on it. Just noticed that there is also a new firmware, so I did that today as well.
      My trouble is I can't get the XY axes stepper motors to turn. They vibrate, but won't turn and they start to make a whining noise. If you try to rotate them - they resist, but then give in and go out of control - either vibrating or spinning without end. Which is the reason why I need help, because I don't know what is causing this.
      I have wired 4 of the same brand motors on top to move the Z axis and that goes up and down no problem, but the XY motors are making really unhappy noises.
      Things I tried - 1. flipping the cable colors on the Duet side (this is in case the motors are wired incorrectly). To my surprise that did nothing, I really thought that was causing the motors not to spin.
      Right now the color scheme is Red/Blue/Green/Black on the Duet side > Red/Black/Blue/Green (I still could be wrong on running them like that, I don't know anymore)
      2.Changing the config file and eventually updating the firmware and web control to the final version.
      No noticeable difference in anything, except now the commands I use to check the rotation of the motors are different (S changed to H)
      Things I haven't tried - changing voltage to the stepper motors. Right now they are all set to Motor current 900mA. They have a current rating at 2.5A/Phase, but in the Configurator the allowed range is 300 to 2400, default 800mA, so I thought that might be OK since the other motors run fine.
      I'm sure it is a trivial problem that I just don't know about. I tried all kinds of helps and troubleshoots and forums, but I couldn't find something that helps me, so I decided to ask here. Hope someone knows exactly what I'm doing wrong.
      • jay_s_uk
        jay_s_uk last edited by
        Do you have details of the stepper motors?
        If you have a multimeter, you can check which colours are from each coil? If you measure between the red wire and the blue wire, you should have no resistance.
        If red and blue are one coil, and green and black are the other coil, then your wiring order seems correct and the next thing to look at is the crimping of the terminals.
        • deckingman
          deckingman @id104335409 last edited by
          @id104335409 Can you post your config.g file as well please.
          • droftarts
            droftarts Moderator last edited by
            @id104335409 Try swapping motors on the motor driver pins, to see if the problem follows the motor, or stays with the driver. I'd think most likely is that there is one phase of each motor that is not connected, ie one of the four wires is not making a connection. This could be caused by a wire break, or a poorly crimped crimp. If you have a multimeter you can disconnect the motor and check the continuity of each pair of wires. See here for other ways to test for the motor phases: https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
            This may also help: https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Checking_connected_stepper_motors
            Remember to turn off power before connecting or disconnecting motors from the pins on the Duet. You can damage the stepper driver if you don't!
            • id104335409
              -Manufacturer: LDO
              -Model: LDO-42STH47
              -Holding Torque: 5.5 kg/cm - 76oz-in
              -Shaft: 5mm
              -Voltage rating: 3.1V
              -Stepping angle:1.8 degrees
              -Current rating: 2.5A/Phase
              -Connector type: JST PH-6
              ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Jan 30 2020 16:44:56 GMT+0200 (Eastern European Standard Time)
              M550 P"QB" ; set printer name
              M667 S1 ; select CoreXY mode
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M92 X80.00 Y80.00 Z1600.00 E420.00 ; set steps per mm
              M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X18000.00 Y18000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
              M201 X3000.00 Y3000.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
              M906 X900 Y900 Z900 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X500 Y500 Z500 S0 ; set axis maxima
              M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
              M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
              M557 X15:215 Y15:195 S20 ; define mesh grid
              I checked the motors with the multimeter and they seem to be fine. Also traced the wires, they are also fine. But the pins inside the connectors do wiggle. I do have one more cable - I could swap it with the ones I tested and try the motor again...
              I am really annoyed how fragile the cables and pins and the Duet PCB is, but the connectors are HARD AS NAILS, so I have to really push/pull, but at the same time I have to be gentle.
              • droftarts
                droftarts Moderator @id104335409 last edited by
                @id104335409 I think you have the motors wired incorrectly; looking at the data sheet http://ldomotors.com/uploads/product_attachment/path/6/LDO-42STH_Info_Sheet.pdf it shows the pairs of wires for each phase are black/green and red/blue. So at the Duet end they should be wired in this order, as the motor driver output pin order is 2B 2A 1A 1B, where the 2s are the pair of wires for one phase, and 1s are the other. The order of each pair doesn't matter, but getting the pairs together does. You can follow the colours on the wiring diagram https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/vqBUAZPsxMC5tRgt.huge
                If this doesn't work, the link I posted earlier shows how to identify the wires of each phase, even without a multimeter; did you try this?
                You will also want to set the current between 50% and 85% of its rated current, so with a 2.5A motor, set the currents to between 1.25 and 2.1A. I'd say around 2A would be fine. With 900mA you're at risk of under-powering the motor, though I'd be surprised if it stalls, unless you've already hooked it up to the axes. So change the M906 line to:
                M906 X2000 Y2000 Z900 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
                The motors on Z and E are different?
                See this page for our general recommendations and guidance about stepper motors (parts of which I linked earlier): https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors
                Note that 0.9º motors for X and Y usually provide the best results on CoreXY machines, rather than 1.8º.
                • id104335409
                  Thank droftarts, the wires to the motors were wired incorrectly - the colors were matching those of the Duet in order for them to work. I am definitely going to up the current to them as well as you recommended.
                  Yes, the Extruder motor is different. I will apply what I learned to it as well. Separate settings.
                  No, I didn't know that 0.9º motors for X and Y provide better results on CoreXY machines.
                  So, motors not running properly - solution: switch cables on motors if possible.
                  Thank you all.
                  If I have more questions should I just post here or make a separate post?
                  • droftarts
                    @id104335409 said in Stepper motors not turning:
                    Glad you got it working. I’d tend to say start a new thread for each individual issue, otherwise threads can get very long and convoluted. Make sure you state Machine setup, firmware version and post current config each time, this goes a long way to getting problems resolved quickly, as people have the context for the problem. Or see https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help
