    Homing error
    • bzadundefined
      bzad
      Hi I’m new here I just got my duet and wired everything up think I’ve done it correctly trying to home (I just did upgrade to v3.0) and I get an error. 285D5245-7EFC-4A1C-BD01-DF62A2C6FC23.jpeg
      Also just noticed heater 0 wasn’t reading -273 when board had firmware 2 now it’s reading that any ideas would help a lot thanks
      • A Former User?
        A Former User
        https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help
          The message says "Attempt to move motors when VIN is not in range". That's a big clue! Most likely cause is a faulty or inadequate PSU, or bad connection between the PSU and the Duet. In particular, check that the screws in the VIN terminal block are tight.
          The current VIN voltage measured by the Duet is displayed on that screen, to the left of the part that you posted. The M122 report will give you the minimum and maximum VIN values seen since M122 was last run, or since power up.
          bzadundefined 1 Reply Last reply Reply Quote 0
          • bzadundefined
            bzad @dc42
            @dc42 thanks i had the lcd connected to wrong port
