    Cura strips indents from conditional G code
    86
    • OwenD
      OwenD last edited by OwenD
      Just a heads up for anyone playing with conditional g code.
      Cura strips leading spaces and tab indents from the start & end G code when you close the program.
      So it’ll work fine when you test it, but next time you open Cura all the indents will be gone, so all commands will be executed.
      e.g the example of
      if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
             G28
      // rest of start code
      will become after restarting Cura
      G28
      Causing G28 to be called regardless of how the IF statement evaluates.
      Veti zapta OwenD 3 Replies Last reply Reply Quote 0
      • Veti
        Veti @OwenD last edited by
        move the code to a macro and call the macro
          This is a good case for using the start.g macro which runs when a print is started before any of the sliced gcode file is executed.
          • zapta
            zapta @OwenD last edited by
            @OwenD, this justified a bug report or feature request (e.g. hard space) from Cura. Saving operation modifying the settings is bad.
            OwenD 1 Reply Last reply Reply Quote 0
            • OwenD
              OwenD @OwenD last edited by
              @OwenD
              Oops. Forgot HTML would strip the spaces as well.
              It was late. LOL
              Yes you can easily use a macro.
              Just remember that if the slicers doesn’t see some settings in the start code, it will automatically add them, so you may still not get the results you planned.
              It’s going to take a while for the slicers you align with the new features.
              As I said, just a heads up.
              A Former User 1 Reply Last reply Reply Quote 0
              • A Former User
                A Former User @OwenD last edited by
                @OwenD said in Cura strips indents from conditional G code:
                put ``` on a line over and below the code to keep the formatting here
                   like so
                • OwenD
                  OwenD @Guest last edited by
                  @bearer 👍
                  • OwenD
                    OwenD @zapta last edited by
                    @zapta Has been submitted
                    https://github.com/Ultimaker/Cura/issues/7056
                    owendare created this issue in Ultimaker/Cura
                    open Support for conditional G Code in start & end GCode #7056
                    zapta 1 Reply Last reply Reply Quote 0
                    • zapta
                      @OwenD, very good. Thanks.
