    BLTouch will not deploy
    127
    • PeteIHughes
      PeteIHughes last edited by
      I am upgrading a CR10S to Duet WiFi, E3D Hemera, AC Mains Heated bed and BLtouch.
      I have used 2 previous Duet Wifi's successfully on a custom 500x500x750 delta.
      I cannot for the life of me get the BLTouch to Deploy
      (I have 2 version 3.1s with standard wiring and 1m extensions)
      Duet Wifi v 1.04
      Firmware version 3.0
      I have wired per https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/
      with the servo on heater 7
      And I have wired per https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
      with the probe on heater 3
      The probe will just not deploy with M401 or the Pin Down Macro
      M280 P7 S10 ; Send PWM channel 7 the s10 (angle) command
      on power up, the BLtouch deploys the probe twice and there is a constant red led.
      NO blue LEDs lit
      Pulling the probe out by hand, the red LED goes out.
      here is my current config.g
      and deploy probe macro
      I have tried different heaters with no success.
      I notice the 3.1 BLtouch no longer has the solder joint to cut to fix the 3.3v logic thing
      ; config.g
      ; Configuration file for Duet WiFi
      G90 ; send absolute coordinates
      M83 ; but relative extruder moves
      M550 P"CR10S" ; printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M92 X80.00 Y80.00 Z3600.00 E420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S60 ; Set idle timeout
      M208 X300 Y300 Z400 S0 ; set axis maxima
      M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
      M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
      M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X44 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20 ; define mesh grid
      T0 ; select first tool
      deployprobe.g
      M280 P7 S10 ; deploy BLTouch
      DIY-O-Sphere 1 Reply Last reply Reply Quote 0
      • Veti
        Veti last edited by
        post a picture of your wiring
        the rrf3 deploy is
        M280 P0 S10 ; deploy BLTouch
        PeteIHughes Phaedrux 2 Replies Last reply Reply Quote 0
        • DIY-O-Sphere
          DIY-O-Sphere last edited by
          @PeteIHughes said in BLTouch will not deploy:
          The Z probe input pin will be zprobe.in on a Duet 2, or one of io4.in, io5.in or io7.in on a Duet 3. If using zprobe.in, you need to enable the pullup resistor using the ^ character in front of the pin name.
          PeteIHughes 1 Reply Last reply Reply Quote 0
          • PeteIHughes
            PeteIHughes @Veti last edited by
            @Veti
            Hope these help.
            As I said, I wired it per https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/
            on heater 7
            Also tried the wiring on this site and heater 3
            • PeteIHughes
              PeteIHughes @DIY-O-Sphere last edited by
              @DIY-O-Sphere
              Sorry, I really don't understand.
              I tried the wiring on the page you linked
              and this in my config.g
              M307 H3 A-1 C-1 D-1
              M558 P9 H5 F100 T2000
              G31 X0 Y0 Z0 P25
              so heater 3 I guess.
              I did not come across any documentation for the pullup resistor ^ thing.
              I am just trying to follow posted documentation
              Thanks
              Pete
              btw, the Ender 3 stock is doing a massive job printing the PETG mount right now
              Phaedrux DIY-O-Sphere 2 Replies Last reply Reply Quote 0
                Phaedrux Moderator @PeteIHughes last edited by
                M307 H3 A-1 C-1 D-1
                G31 X0 Y0 Z0 P25
                This is for firmware 2.0. Are you using Firmware 3.0 or no? Your original config looked almost correct for RRF3.
                • DIY-O-Sphere
                  DIY-O-Sphere @PeteIHughes last edited by
                  @PeteIHughes
                  Sorry the link wasn't copied as expected....
                  https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_RepRapFirmware_Num_3
                  You have wired to heater 7 so the code should be
                  M558 P9 C"^zprobe.in" H5 F120 T6000
                  You don't need the mod pin....
                  • DIY-O-Sphere
                    DIY-O-Sphere @PeteIHughes last edited by DIY-O-Sphere
                    @PeteIHughes
                    Also check the endstop setting
                    That would use an connected endstop
                    Normally with Bltouch the probe is used as endstop
                    • PeteIHughes
                      @DIY-O-Sphere
                      Thanks for all the help BTW
                      Unfortunately, none of the above suggestions has affected anything.
                      It is not that the BLtouch isn't probing correctly.
                      The issue is that the probe doesn't move at all.
                      The probe servo is not moving the tip out.
                      It does so twice on power up, but never again.
                      M401 does nothing.
                      It is almost like it is dead, but as I said, I have 2, and 2 sets of wires.
                      So I believe that the Duet is not sending a signal to operate the probe pin..
                      I have a multimeter if needed to check duet pin outputs,
                      and worse case scenario, I have a stock ender 3 I could test it on.
                      Thx again
                      Pete
                      • PeteIHughes
                        I am on Duet Web Control ver 2.0:4
                        Wifi Server ver 1.22
                        Wifi/ethernet 3.0
                        2020.01.03b3
                          Phaedrux Moderator @Veti last edited by
                          @Veti said in BLTouch will not deploy:
                          the rrf3 deploy is
                          What do you have in your deploy macro? Does it match what veti says here?
                          • DIY-O-Sphere
                            Then the Bltouch is working
                            Have you tried "M280 P0 S10" in DWC?
                            • PeteIHughes
                              @DIY-O-Sphere
                              That worked !!!!!!!
                              so my guess is that my deploy probe "g" file is bad.
                              It is all lower case.
                              could that be it ?
                              • DIY-O-Sphere
                                DIY-O-Sphere last edited by DIY-O-Sphere
                                @PeteIHughes
                                If they are from RRF2 you have to edit the content
                                deployprobe.g
                                M280 P0 S10
                                retractprobe.g
                                M280 P0 S90
                                  dc42 administrators @PeteIHughes last edited by dc42
                                  @DIY-O-Sphere
                                  That worked !!!!!!!
                                  could that be it ?
                                  No, lowercase is fine. The difference is the M280 P parameter. In RRF2, the P parameter is the logical pin number, which for heater pins is the same as the heater number. In RRF3 is it the number of the servo device that you created using the M950 S command.
