    Hyperube HEVO with DUET3
    My Duet controlled machine
    • tobias_munichundefined
      tobias_munich
      Hi together,
      may i introduce...
      Since nearly 6 months I am working on this machine and its still "work in progress"
      Build: Hypercube HEVO, Dual Z, 300x300x400
      Board: DUET3 + SBC Raspberry Pi4
      Firmware: RRF3 Beta 3
      Extruder: Zesty Nimble
      Z-Sensor: Orion Piezo
      X-Min, Y-Min: optical Endstops
      DHT22: for chamber temperature
      Webcam: RPI-Cam and RPICamControl -> https://elinux.org/RPi-Cam-Web-Interface
      Power Control and Monitoring: Sonoff POWR2 with Tasmonta 8.0.1
      LEDs: Control WS2812B RGB LEDs with an ESP8266 over WiFi! -> https://github.com/Aircoookie/WLED
      Dashboard: Homeassistant
      Hypercube-Evolution, Dual-Z, Nimble v2, Orion Piezo
      Duet3, DuetWifi, Raspberry Pi 4, 7 inch HDMI Display, Panel-Due
      Firmware: RepRapFirmware for Duet 3 MB6HC 'always the latest release'
      droftartsundefined 1 Reply Last reply Reply Quote 1
        droftarts administrators @tobias_munich
        @tobias_munich Nice! I've just started a HEVO build. Did you use the standard parts, community modified or design your own?
        tobias_munichundefined 1 Reply Last reply Reply Quote 0
          tobias_munich @droftarts
          @droftarts thanks.
          no I'm not using the standard parts. I am using the reinforced versions.
          all my parts are with normal nuts and all parts are more stable
          the main parts - reinforced.
          https://www.thingiverse.com/thing:2437440
          y-carriage:
          https://www.thingiverse.com/thing:3501612
          these idlers:
          https://www.thingiverse.com/thing:2186358
          and this hoted-mount for my nimble & orion piezo
          https://www.thingiverse.com/thing:2617424
            @tobias_munich Thanks for the links, that will be really useful! Especially the ones done in Fusion 360 which I can edit to my needs.
