Help: Temp Sensors and Homing Issues
Just replaced Hotend heater and Thermistor did Heater auto tune and it was successful with New 24v 40W Heater Cart. and an NTC 3950 Stud Thermistor
![alt text](
image url)
Features:
Using 22AWG cable, the copper inside is very thick, it is resistant to current 2A, voltage 300V.
The nonconductor has a wide range of temperatures, up to 80 centigrade.
It is not easy to be snapped and convenient to be plugged in and unplugged.
For convenience, the plug on the other side is integrated , you can use the plug directly.Connection description:
- Bed wire connect VCC (+ of ramps)
- Black wire connect GND (- of ramps)
- Green wire connect SIGNAL (s of ramps)
One set includes:
- 1x endstop switch
- 1x 3-pin 27.5inch cable
What is in the package:
2 set endstop switches for RAMPS 1.4 -
Yes those switches would likely need to be inverted. See my post above.
What firmware version are you running exactly? Send M115 and post the response.
console (2).txt Results posted Fixed my Z and Changed my endstops to inverted with the Exclamation Fix Thanks
M500: Warning: No M501 command was executed in config.g
Don't forget to add M501 to the end of config.g or your tuned values won't be loaded at boot.
Ouickie: Is their a way to disable and enable motors so that i may level my bed with my Boro glass.
When homing Z at the end of run Command it is hitting my nozzle causing my bed to tilt a few degrees
Post your homing files.
Is it using a probe, or an endstop?
If the nozzle is hitting the bed before the endstop is triggered you'll need to move the endstop so that it gets triggered first. If it's hitting the endstop but not stopping you should test the endstop switch to see if it's triggering at all when pressed.
; homey.g
; called to home the Y axis
; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Feb 20 2020 15:06:37 GMT-0800 (Pacific Standard Time)
G91 ; relative positioning
G1 H1 Y215 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 H2 Y-5 F6000 ; go back a few mm
G1 H1 Y215 F360 ; move slowly to Y axis endstop once more (second pass)
G1 H2 Z-5 F6000 ; lower Z again
G90 ; absolute positioning; homex.g
; called to home the X axis
G1 H1 X235 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 H2 X5 F6000 ; go back a few mm
G1 H1 X235 F360 ; move slowly to X axis endstop once more (second pass)
; homez.g
; called to home the Z axis
G1 H1 Z205 F1800 ; move Z up until the endstop is triggered
G92 Z0 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioningZ axis goes a few mm beyond my Z Endstop which forces my endstop to slightly be tilited up
https://drive.google.com/open?id=1E3CcR-HoAqUtBcpq_rlf7GUoT6-3kfUs
https://drive.google.com/open?id=1DyAeQrRzdj33uJVOVafkc-4hT0_O2bQ1
And if you hit the endstop with your finger does the status change in the machine specific tab?
Had to issue M84 and manually lower my bed to test trigger my z endstop status states NO when not hit then turns to YES when Hit
@94118 said in Help: Temp Sensors and Homing Issues:
Remove this from homez. Maybe you were already too close to the endstop at the start of homing.
If you lower the bed and then home does it move towards the endstop?
Try and click it with your finger before the bed hits it. If the endstop doesn't stop it moving, power off the printer to prevent damage.You can also use M913 Z40 to reduce the motor current at the start of homez and then use M913 Z100 to return motor current back to normal at the end. That should also help limit the potential for damage.
That worked: Nice soft Stop at my endstop and adjusted my height down to 200mm was set at 205mm would it be better to just remove the Z movement from X and Y also
You could since you aren't using a probe or anything that would need to be raised above the bed before movement.
Would i be all good to load filament and try a test print
Machine movement controls not responsive i click on the fine movement tabs and it does noting machine is in idle
So the printer will home properly but then you can't use the jog buttons in DWC?
Yes that is correct
Can you send movement commands in the console?
Do the paneldue move buttons work? -
No i cannot send commands from console or paneldue
