    How to Set Z home
    • Keith53
      Keith53 last edited by
      I am using a switch to home XYZ. When I home Z the nozzle is about .3mm below the bed. I have been trying figure out how to set it so it knows this. When I home XY the web interface shows X-33 Y-10 but Z still shows Z0.0.
      M208 X-33 Y-10 Z-0.3 S1 ; set axis minima
      M208 X220 Y220 Z240 S0 ; set axis maxima
      I also tried editing the homeZ.g and the homeall.g
      G92 Z0.3 ; set Z position to axis minimum (you may want to adjust this)
      What am I doing Wrong?
        Phaedrux Moderator @Keith53 last edited by
        Can you post your homing files? Maybe your full config.g too.
        Do you mean that the nozzle is pushing into the bed surface? How are you measuring -0.3?
        When you trigger the endstop the position is set to either the minima or maxima from M208. So triggering the zmin endstop should set the position to -0.3 as you have that as your minima. Unless it's being reset with an G92 Z after hitting the endstop.
        Keith53 1 Reply Last reply Reply Quote 0
        • Danal
          Danal last edited by
          @Keith53 said in How to Set Z home:
          Have you tride G91 Z-0.3?
          • Keith53
            Keith53 @Phaedrux last edited by
            @Phaedrux said in How to Set Z home:
            The G92 Z0 was resetting it in the homeall.g and homez.g files. I commented out ;G92 Zxxx and now when it is on the Z end stop it shows what is in M208 below Thanks!
            Not sure why G92 Z-.03 did not work. I use G92 on mills at work sounds like it should do the same thing on the printer.
            G92 "Change Work Coordinate System"
            G92 X0 Y0 Z=VTOFH[VTLCN]+12.7
            This would set where the spindle is now to X0 Y0 and Z would be the current tool in the spindles length+12.7
              I'd have to see the actual file to venture a guess.
              Using G92 in the homing files is a bit of a kludge honestly. Best to refrain if possible.
