    G28 Bad Dommand
    409
    • H2SO4undefined
      H2SO4
      Hallo,
      since a few Weeks I used the Duet 2 Wifi Board in my Prínter, and it works very good.
      Only one little Problem is there:
      When I start "homing all axes", the Board shows "G28 Bad Command"
      The homing procedure runs well.
      Does anyone have experience with this problem, I would be very grateful for advice?
      Here are the files config.g and homeall.g
      ; generated by RepRapFirmware Configuration Tool v2.1.4 on Sun Dec 22 2019 16:22:28 GMT+0100 (Mitteleuropäische Normalzeit)
      G90                                     ; send absolute coordinates...
      M83                                     ; ...but relative extruder moves
      M550 P"Printer"                           ; set printer name
      M667 S1                                 ; select CoreXY mode
      M552 S1                                 ; enable network
      M586 P0 S1                              ; enable HTTP
      M586 P1 S0                              ; disable FTP
      M586 P2 S0                              ; disable Telnet
      M569 P0 S1                              ; physical drive 0 goes forwards
      M569 P1 S1                              ; physical drive 1 goes forwards
      M569 P2 S0                              ; physical drive 2 goes backwards
      M569 P3 S1                              ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                        ; set drive mapping
      M350 X128 Y128 Z128 E128 I0             ; configure microstepping without interpolation
      M92 X640.00 Y640.00 Z12800 E761.60      ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00     ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z250 E1200.00    ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00     ; set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1500 E1800 I30        ; set motor currents (mA) and motor idle factor in per cent
      M84 S10                                 ; Set idle timeout
      M208 X0 Y0 Z0 S1                        ; set axis minima
      M208 X240 Y240 Z200 S0                  ; set axis maxima
      M574 X1 Y1 S0                           ; set endstops controlled by motor stall detection
      M574 Z1 S2                              ; set endstops controlled by probe
      M558 P5 H5 I1 F120 T4800                ; set Z probe type to switch and the dive height + speeds
      G31 P500 X0 Y0 Z0.55                    ; set Z probe trigger value, offset and trigger height
      M557 X2:220 Y2:220 S110                  ; define mesh grid
      M305 P0 T100000 B4138 R4700             ; set thermistor + ADC parameters for heater 0
      M143 H0 S70                             ; set temperature limit for heater 0 to 70C
      M305 P1 T100000 B4138 R4700             ; set thermistor + ADC parameters for heater 1
      M143 H1 S250                            ; set temperature limit for heater 1 to 250C
      M106 P0 S0 I0 F500 H-1                  ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H-1                  ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P0 D0 H1 F0                        ; define tool 0
      ;G10 P0 X0 Y0 Z0.0                      ; set tool 0 axis offsets
      ;G10 P0 R0 S0                           ; set initial tool 0 active and standby temperatures to 0C
      M915 X Y S5 R0				; Configure motor stall detection
      M106 P0 F25            			; Set Fan0 Freq to 25 Hz
      M501					; Read stored parameters
      ; homeall.g
      ; called to home all axes
      G1 H2 Z5 F1500          ; lift Z relative to current position
      ;G1 H1 X-250 Y-250 F100 ; move quickly to X or Y endstop and stop there (first pass)
      G1 H1 Y-250             ; home Y axis
      G1 H1 X-250            ; home X axis
      G1 X5 F1500             ; go back a few mm
      G1 H1 X-250 F360        ; move slowly to X axis endstop once more (second pass)
      G1 Y5 F1500             ; go back a few mm
      G1 H1 Y-250 F360        ; then move slowly to Y axis endstop
      G1 X120 Y120 F1500      ; go to first bed probe point and home Z
      G30                     ; home Z by probing the bed
      G1 Z5 F1500             ; go back a few mm
      ;G91                    ; relative positioning
      ;G1 S2 Z5 F80           ; lift Z relative to current position
      ;G90                    ; absolute positioning
      Phaedruxundefined Vetiundefined 2 Replies Last reply Reply Quote 0
      • A Former User?
        A Former User
        Edit the post and put ``` on a line over and under the config. Makes it much easier to read and see things like whitespace/line shifts
          Phaedrux Moderator @H2SO4
          @H2SO4 said in G28 Bad Dommand:
          How exactly are you initiating that action?
          • H2SO4undefined
            H2SO4
            With the "Home ALL Button" in Web Control, but it is the same when i use G28 in Slicr Startcode
              Can you manually copy and paste each line of the homeall macro into the console command line and execute them one at a time and see if you still get the same error and which line causes it.
                Do you have deployprobe.g and retractprobe.g files in /sys on the SD card? If so, please post their contents.
                H2SO4undefined 1 Reply Last reply Reply Quote 0
                • H2SO4undefined
                  H2SO4 @dc42
                  no, the deployprobe.g and retractprobe.g files in /sys are not on the SD card
                  • Vetiundefined
                    Veti @H2SO4
                    unrelated to the homing problem.
                    unless you have a very specific reason you should be running at x16 with interpolation on. high microstepping could overload the cpu and cause hickups.
                    also your thermistors are not configured properly. B4138 is the default and wrong for your thermistors.
                    H2SO4undefined 2 Replies Last reply Reply Quote 1
                      Phaedrux Moderator @Phaedrux
                      @Phaedrux said in G28 Bad Dommand:
                      Did you try this yet? What type of probe are you using?
                      • H2SO4undefined
                        H2SO4 @Veti
                        @Veti said in G28 Bad Dommand:
                        Thank You,
                        when B4138 is the wrong setting, what is the correct value?
                        • H2SO4undefined
                          H2SO4 @Veti
                          @Veti
                          Hallo,
                          after some read i've found this Setting:
                          M305 P1 B4725 C7.060000e-8
                          it that o.k.?
                          Thank You
                            droftarts administrators @H2SO4
                            Try M305 P1 T100000 B4725 C7.060000e-8 R4700
                            Is your bed thermistor the same?
                            • H2SO4undefined
                              H2SO4
                              Sorry,
                              i'm new with this themes
                              was i mean are the settings for the Hotend, also P0
                              it is a E3D lite
                                @H2SO4 E3D Lite uses 100K Semitec 104GT2 NTC thermistor https://wiki.e3d-online.com/E3D-Lite6_Documentation
                                If the hot end and bed both have this thermistor, settings should be:
                                M305 P0 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 0
                                M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
                                P0 is bed, P1 is hot end.
                                Have you resolved the problem with 'G28 Bad command'?
                                • H2SO4undefined
                                  H2SO4 @Phaedrux
                                  @Phaedrux
                                  Hallo, I try this, but it don't work
                                  the Board shows the same G28 Bad Command
                                  for Z-Probe i use a npn inductive sensor from China
                                  Thank You
                                    But on which line of the macro does it give the error?
                                    • H2SO4undefined
                                      H2SO4 @Phaedrux
                                      @Phaedrux
                                      Hallo, i have create a new config.g File with the Config Tool and now it runs well
