Replacing U2 on board
U2 got fried for unknown reasons yet and I replaced it. Its working now but its not the exact same part (pinout match though). The one I have now is only 500mA instead of 1A
Is this enough or do I need to put one to have the full 1A ?
Thanks,
J-F
(you might want to add if its a wifi or ethernet board as it might influence the answer)
A 500mA regulator will probably be adequate. Peak current draw when the WiFi module is transmitting will exceed 600mA, but only for short periods.
i have the wifi version.
hum.. not sure i like that it peaks that high off specs. i might change it then.
thank you for your help
