    Large Delta printer not homing on an original duet Maestro
    Example setups and prints
    2.3k
    • NEVER LUCKYundefined
      NEVER LUCKY
      this is embarrassing what is the g code for inserting sd card again?
      • Danalundefined
        Danal
        Power off whenever inserting or removing SD.
          You can also use M21 and M22 to load and eject the SD card.
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M21_Initialize_SD_card
          • Danalundefined
            Danal
            Well, I learn something every day! Thanks @Phaedrux
              NEVER LUCKY
                NEVER LUCKY
                ill wire things up and test if i can connect the web interface
                  That's a really good sign.
                    NEVER LUCKY
                    so i wired everything up and checked the endstops. it looks kinda good i guess.
                    After i pressed HOME ALL, the axes did what they were supposed to.
                    I want to thank all three of you guys for staying up this late and helping me figure this out and also for not giving up when i had no idea what could be done otherwise.
                    cheers lads and thanks so much.
                    @Danal @dc42 @Phaedrux
                      NEVER LUCKY
                      • Danalundefined
                        Danal
                        Wooo Hooo!
