    why is my filament sensor not stopping print?
    • 57buickundefined
      57buick
      M574 X1 Y1 S0 ; Set active low endstops
      M591 D0 P1 C3 ; simple switch
      why does my print not stop? I can see under machine properties the E0 endstop changes whether there is filament or not but print does not pause
      • SIamundefined
        SIam
        @57buick said in why is my filament sensor not stopping print?:
        E0
        which firmware your running on the duet? post the result of m115 and from M591 D0
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        • 57buickundefined
          57buick
          Im running version 2.05
          I changed the line to M581 E0 T1 S0 C1 and it appears to be working now not sure the difference between M591 and M581 but it works
          • ktapperundefined
            ktapper
            You did not enable the sensor
            M591 D0 P1 C3 S1; simple switch
              droftarts administrators @57buick
              @57buick Better to use M591, not M581. See https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing
              You need S1 to enable it, so M591 D0 P1 C3 S1
              Edit: @ktapper beat me to it!
