    Heating fault (rising too slowly, RRF 3.01 from RRF 2.05)
    • tom_Nbgundefined
      tom_Nbg
      I've just updated the FW from 2.05 to 3.01. Everythings seems to work fine (after some small issues).
      But now I've got this problem:
      The bed is heating - I see it at the rising temp. (which is indeed slower than before with 2.05)
      With 2.05 I had no problems:
      Here my old 2.05-Config:
      M307 H0 B0 S1.00                                 ; disable bang-bang mode for the bed heater and set PWM limit
      M305 P0 T100000 B4138 R4700                      ; set thermistor + ADC parameters for heater 0 - from RRF Configurator
      M143 H0 S120                                     ; set temperature limit for heater 0 to 120C
      and here the new one for 3.01:
      M308 S0 P"bedtemp" Y"thermistor"  A"Bed" T100000 B4138            ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                                     ; create bed heater output on bedheat and map it to sensor 0
      M140 H0                                                   ; map heated bed to heater 0
      Thank you!
      • SIamundefined
        SIam
        try to make PID Tuning for the bed
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        • tom_Nbgundefined
          tom_Nbg
          Thank you!
          I'll try this, but I'm just wondering, why I hadn't this fault when running RRF 2.x ?
            dc42 administrators @tom_Nbg
            @tom_Nbg said in Heating fault (rising too slowly, RRF 3.01 from RRF 2.05):
            Thank you!
            It's because RRF 2.x assumes that heater 0 is the bed heater, so it uses different M307 default parameters for it that assume a slower heating rate.
            • tom_Nbgundefined
              tom_Nbg
              @dc42 , @SIam
              Thank you again!
              It is working now and I understood why 🙂
