    Warning High temperature on drivers... - WORKBEE Duet 2 WiFi
    567
    • stweetundefined
      stweet
      Have a workbee 750x750 with duet 2 wifi and default workbee fw & settings.
      After machine is on for 5-10 minutes i get a "DWC warning: High temperature on drivers..." and it feels like the step motors start to get fairly hot..
      why do they get to hot so fast ?
      Vetiundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti @stweet
        what current are you running them at?
        • aidarundefined
          aidar
          Workbee default setting is 2400mA. Maybe its too much for your motors?
          • stweetundefined
            stweet
            @Veti @aidar
            M906 X2400 Y2400 Z2400 I100 ;
            motors: 2303HS280AW ( should be able to run 2.8a)
            • aidarundefined
              aidar
              Duet Wifi-s drivers itself are rated to maximum 2.4A, so to get max out of it you should use very good cooling for drivers i guess.
              • A Former User?
                A Former User @stweet
                @stweet said in Warning High temperature on drivers... - WORKBEE Duet 2 WiFi:
                and theyre rated for at temperature increase of 80C and up to 50C ambient i.e. they'll get hot, real hot. its normal.
                do you need to run such a high current?
                • Vetiundefined
                  Veti @aidar
                  @aidar
                  if you run the stepper drivers at 2400ma you will need to actively cool them.
                  a can that blows across the underside of the board should do it.
                  • stweetundefined
                    stweet
                    @Veti @bearer year it sounds like i need better cooling on the pcb
                    • A Former User?
                      A Former User
                      cooling the board won't affect the motor temperature just if that was unclear.
                      • stweetundefined
                        stweet
                        @bearer yea i know but i set it to 1.8A motors are ok cool, but i felt drivers with my finger and they are pretty hot
                          https://duet3d.dozuki.com/Wiki/Mounting_and_cooling_the_board
