Duet Maestro Bed heating uncontrolled
@bearer
OK so now I am really confused.
I am seeing 24 volts at R65, D6 and D5 immediately on powering the board.
Now I am not even sure if the mosfet was damaged or if something is going on upstream.
@NTX9 said in Duet Maestro Bed heating uncontrolled:
if you look at the schematic and realize V_BED is 24v then it might make more sense?
in any case the gate resistor is R20 as highlighted on the pcb screenshot, if you want to go digging you'll find all the files on github
https://github.com/T3P3/Duet/tree/master/Duet2/Duet2v1.04 -
@bearer
The voltage is showing up even when the bed temp is set to zero?
@bearer
V_BED doesn't change unless you pull the fuse, with no current flowing there will be no voltage drop and all voltages will for those parts will be Vin essentially; but its irrelevant to using the gate signal from R20.
@bearer said in Duet Maestro Bed heating uncontrolled:
https://github.com/T3P3/Duet/tree/master/Duet2/Duet2v1.04Thanks !
@bearer
Thanks again, now I see that the bed PWM feeds through R20 to the mosfet gate. I am a little slow but starting to get how this thing works.
@Phaedrux said in Duet Maestro Bed heating uncontrolled:
Is it possible to edit the firmware to use E1 to control an external mosfet?
Should be able to configure that. What firmware version are you running? If you're using RRF3 you can define a different pin.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M307_Set_or_report_heating_process_parameters
If you're using RRF2 check out M140 H1 https://duet3d.dozuki.com/Wiki/Gcode#Section_M140_Set_Bed_Temperature_Fast
This seems like my least painful option. I am on firmware 2.03.
Thanks It may be a few days but I will get back once I have time to try this.
@NTX9 I said M140 H1, but the H# will depend on where you have the extruder. May be H2 for you.
May be a good idea to update to 2.05.1 as well for all the bug fixes etc.
My E1 heater port is open on the board. Is that H1 in the firmware?
No, in RRF2 H0 is the bed heater port, H1 is the E0 heater port, and H2 is the E1 heater port.
Ha I am glad I asked...
