    Invert extruder motor direction?
    Firmware installation
    4.9k
    • claustroundefined
      claustro
      I know it is a dumb question , and I could simply turn the motor connector 180 degree, but I would like to understand what I am doing wrong.
      [c];M575 P1 B57600 S1 ; Comms parameters for PanelDue; Machine configuration
      M569 P0 S0 ; Drive 0 goes forwards (change to S0 to reverse it)
      M569 P1 S0 ; Drive 1 goes forwards. (Change if motor goes wrong way. Or just turn the motor connection 180 degrees around..)
      M569 P4 S1 ; Drive 4 goes forwards
      M574 X1 Y2 Z0 S0 ; set endstop configuration (X1 is at MIN end. Y2 is at MAX end. (active high switch = S1, active low switch= S0)
      M667 S1 ; set CoreXY mode[/c]
      I tryed to change M569 P0 S0 to M569 P0 S1 with no luck I tried changing "S " at all the drive with no luck.
      Can someona tell me what I am missing?
      • T3P3Tonyundefined
        T3P3Tony administrators
        So the drives are mapped like this by default:
        0 = X
        1 = Y
        2 = Z
        3 = E0
        4 = E1 etc
        Assuming you are referring to extruder 0, you should change the line:
        [[language]]
        M569 P3 S1
        To
        [[language]]
        M569 P3 S0
        www.duet3d.com
        • claustroundefined
          claustro
          Thank you!
          • stavrosgmtlundefined
            stavrosgmtl
            I love the duet, saved my butt, thanks!
