    D3+Pi hangs and sometimes won't reset
    Beta Firmware
    427
    • Danalundefined
      Danal
      Using Duet 3 6HC and Raspberry Pi 4B, when certain homing moves do not complete, the printer hangs and an "emergency stop" via DWC will not un-hang it. A power cycle, a reboot of the Pi, or a systemctl stop/start of duetcontrolserver is required to unhang it.
      Example to reproduce:
      • Unplug a NC switch on Y axis. Home Y axis only. Hangs.
      • Reset via "emergency stop" button. Messages are received indicating a reset, etc. occured
      • Attempt to home X (not Y). Hangs.
      Board: Duet 3 MB6HC (MB6HC)
      DSF Version: 1.2.4.0
      Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.0 (2020-01-03b3)
      • gtj0undefined
        gtj0
        I've seen the same thing. I think the Duet Control Server looses it's mind in those situations.
        Danalundefined 1 Reply Last reply Reply Quote 0
        • Danalundefined
          Danal @gtj0
          @gtj0 said in D3+Pi hangs and sometimes won't reset:
          Agreed. At the same time, the M999 "passes through" the control server, and it ought to restart itself.
          • spllgundefined
            spllg
            following
            • projectR3Dundefined
              projectR3D
              Im having similar issues and also homing can be inconsistent where it will hit the endstop and stop but the unit says it didnt home. My units running DSF 1.1.0.5 works well but anything 1.2 seems to mess up
              • oliofundefined
                oliof
                I had this problem as well, logging into the Pi and restarting the duet software framework service unblocks it.
                • gtj0undefined
                  gtj0
                  I think we're all waiting on @chrishamm to get back to work. 🙂
                  tobias_munichundefined 1 Reply Last reply Reply Quote 0
                  • tobias_munichundefined
                    tobias_munich @gtj0
                    same topic,
                    I disconnected the SBC for the moment to have a more reliable environment.
                    hope this will be fixed soon.
                    Hypercube-Evolution, Dual-Z, Nimble v2, Orion Piezo
                    Duet3, DuetWifi, Raspberry Pi 4, 7 inch HDMI Display, Panel-Due
                    Firmware: RepRapFirmware for Duet 3 MB6HC 'always the latest release'
