    Hotend and Heated bed reading 2000deg celcius and fault
    1.7k
    • NEVER LUCKYundefined
      NEVER LUCKY
      hi , I have an issue with heating the bed and hotend on a duet2 maestro. On the web control it says that they are both 2000 degrees celcius, but they aren't even heated a bit when i touch it. Heater 1 and Heater 0 are both fault and every time i reset it, nothing changes and they go back to being fault.
      I measured the resistance of both of the thermistors at room temperature.
      Hotend: original E3D Thermistor Cartridge
      115kOhms
      Bed thermistor: 100K EPCOS B57540G0104J
      120kOhms
      The connection and crimps are fine.
      Both termistors i have soldered to some wire to extend the length.
      I get error messages in console after resetting , and also when i click on TestHeaters in Macros in the web control.
      I might have chosen the wrong options when creating the configuration, so i will include screenshots of the files.
      • appjawsundefined
        appjaws
        It looks like you have the wrong names and I can not see where you have defined M950
        Here is my config, hope that helps
        ; Thermistors and heaters
        M308 S0 P"bed_temp" Y"thermistor" T100000 B3950 H3 ; configure sensor 0 as thermistor on pin bedtemp
        M950 H0 C"bed_heat" T0 ; create bed heater output on bedheat and map it to sensor 0
        M143 H0 S70 ; set temperature limit for heater 0 to 70C
        M307 H0 A91.0 C504.1 D1.3 S1.00 V24.4 B0 ; Auto tune PID for bed heater
        M308 S1 P"e0_temp" Y"thermistor" B4388 H25 ; configure sensor 1 as thermistor on pin e0temp
        M950 H1 C"e0_heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
        M143 H1 S230 ; set temperature limit for heater 1 to 230C
        M307 H1 A744.5 C243.5 D4.4 S1.00 V24.5 B0 ; Auto tune PID for extruder 0
        appjaws - Core XYUV Duet Ethernet Duex5
        firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
        Ormerod 1-converted to laser engraver, Duet wifi
        OpenSCAD version 2024.03.18
        Simplify3D 5.1.2
          NEVER LUCKY
          It's still not working. still same problems.
          • appjawsundefined
            appjaws
            can you post your complete config.g
            What firmware are you using?
            Where have you connected the heaters and sensors on the board?
            Simplify3D 5.1.2
              NEVER LUCKY
              ; Configuration file for Duet Maestro (firmware version 3)
              ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Jan 18 2020 15:59:57 GMT+0100 (Central European Standard Time)
              M550 P"Colossus" ; set printer name
              M665 R154 L324 B150 H700 ; Set delta radius, diagonal rod length, printable radius and homed height
              M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
              M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
              M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
              M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
              M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 Z0 S1 ; set minimum Z
              M574 X2 S1 P"xstop" ; configure active-low endstop for high end on X via pin xstop
              M574 Y2 S1 P"ystop" ; configure active-low endstop for high end on Y via pin ystop
              M574 Z2 S1 P"zstop" ; configure active-low endstop for high end on Z via pin zstop
              M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
              M557 R85 S20 ; define mesh grid
              M303 H1 S240 ; auto tune heater 1, default PWM, 240C target or maximum temperature
              M303 ; report the auto-tune status or last result
              M143 H0 S130 ; set temperature limit for heater 0 to 130C
              M563 P0 S"Extruder_TOOL" D0 H1 F0 ; define tool 0
              • appjawsundefined
                appjaws
                You did not change the P parameter, it should be:-
                M308 S0 P"bed_temp"
                M308 S1 P"e0_temp"
                Simplify3D 5.1.2
                  NEVER LUCKY
                  i changed it now and it still isnt doing it
                    dc42 administrators @NEVER LUCKY
                    @NEVER-LUCKY said in Hotend and Heated bed reading 2000deg celcius and fault:
                    Why do you have M303 commands in config.g? They don't belong there! They are for manual use only.
                      NEVER LUCKY
                      i removed it and still no results. same problem and for some reason the hotend fan stopped spinning last night.
                        droftarts administrators @NEVER LUCKY
                        @NEVER-LUCKY Please send M115 to the Duet and post the reply. Your config.g is set up for RepRapFirmware 3, but I think your Duet is running RepRapFirmware 2.
                          NEVER LUCKY
                            NEVER LUCKY
                            im really lost here. what should i do?
                              @NEVER-LUCKY Yes, you're using a config.g file for RRF3, but your board has RRF 2.05.1. The first line of your config.g is ; Configuration file for Duet Maestro (firmware version 3) So the config tool does tell you what firmware version it's for.
                              Is this a new board, or was it working before? If this is a new install, either:
                              • If you have the config.json file you used to generate your current config.g, go to the RRF config tool and load it. Then, on the 'General' tab, change the firmware version from '3.0 or later' to '2.03 to 2.05'. Then go through and check that it's set up correctly, export config.g, and try that.
                              Or
                              • Update your Maestro to RepRapFirmware 3 (which is going to be the future of the firmware) and sort out config.g issues there.
                              If it was working before, revert to the config.g you were using.
                                NEVER LUCKY
                                @droftarts said in Hotend and Heated bed reading 2000deg celcius and fault:
                                RRF config tool
                                oh nice. its doing fine now.
                                however im getting new errors: the hotend doesnt heat up and is at -273,1 and the bed gets the error for heating up slowly.
                                  @NEVER-LUCKY Which did you do, update to RRF 3, or generate new config.g? If new config.g, post it. Please post the whole config.g, as text, in the 'code' tags, using </> from the formatting bar.
                                  -273 means that the thermistor is not connected. Probably you have defined it for the wrong pins.
                                    NEVER LUCKY
                                    i updated the firmware to 3.0.
                                    M584 X0 Y1 Z2 E3                                   ; set drive mapping
                                      NEVER LUCKY
                                      i didnt change a thing in the config and didnt generate a new one. only the RRF is 3.0 now
                                        @NEVER-LUCKY Okay. Hot end thermistor should be on e0temp, the right-hand two-pin connection here:
                                        If it is, can you test the wiring with a multimeter? If not, try swapping bed and hot end thermistors connections, see if you get a reading for the hot end thermistor on the bed.
                                          NEVER LUCKY
                                          alright! its all fine the wiring was wrong... so dumb of me!
                                          the bed heater is still fault for rising slowly though.
                                            @NEVER-LUCKY You'll need to tune the bed with M303. RRF3 doesn't assume that any heater is a bed, so it just thinks something is wrong.
                                            First, you need to get your temperature sensors reporting accurately. You're using:
                                            T100000 B4138 is the default thermistor setting, for a Honeywell 135-104QAD-J01 thermistor that shipped with hot ends from RepRapPro, who have been out of business for 4 years! So I doubt you have the correct thermistor settings, and likely the temperature your heaters are reporting is not accurate. All 100k ohm thermistors have a resistance of 100k ohms at 25C, and will be fairly accurate at room temperature, but they report very differently as they get hotter. So please check what thermistors you have in your bed and hot end, and set them correctly, then you have a chance of accurately setting extrusion temperature.
                                            Then, your heater settings. For full details see: https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                                            Your heater settings are at the default. It looks like you haven't tuned your heaters THEN sent M500 (to store them to config-override.g). Alternatively you can copy the heater tuning to config.g. This hasn't been done, as the heater profiles in your config.g are still:
                                            M307 H0 B0 S1.00
                                            M307 H1 B0 S1.00
                                            While the hot end will probably heat up, the temperature control won't be smooth. So, tune heaters with something like:
                                            M303 H0 S60
                                            M303 H1 S200
                                            Run them each a number of times (usually three times will do), but wait for the heater to be at room temperature before doing it again. Once the results converge, send M500 to save them to config-override.g
                                            Then either add M501 to the end of config.g so they load from config-override.g, or copy the heater settings to config.g
                                            You can check the current heater settings by sending M307 H0 or M307 H1 from the console.
