Z Problem Corexy
  • Hi
    This is my conf:
    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Mar 01 2020 23:52:56 GMT+0100 (Central European Standard Time)
    M550 P"Sapphire" ; set printer name
    M667 S1 ; select CoreXY mode
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P2 S0 ; physical drive 2 goes forwards
    M92 X80.00 Y80.00 Z400.00 E415.00 ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
    M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X300 Y300 Z350 S0 ; set axis maxima
    M574 X1 Y1 Z2 S0 ; set active high endstops
    M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
    M557 X15:215 Y15:195 S20 ; define mesh grid
    M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
    M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
    ; Hotend
    M143 S260 ; max hotend temperature to 260C
    M307 H1 A290.3, C119.0, D10.9 S0.6 ; PID heather
    ;M305 P0.6 X100 ; heater P1/H1 on channel 1
    M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    My Z start goest down and doesn't stop...why?
    I tried also to put only G28 in my start Gcode but the Z goes down...In the duet console home x y and z and home all works fine
  • Moderator
    Please post your homing files and start gcode as well.
  • This my start gcode:
    G1 X0.0 Y300.0 Z1.0 F1000.0 ; prepare to prime
    G92 E0 ; reset extrusion distance
    G1 Z0.2 F1000.0
    G1 X60.0 Y280 E9.0 F1000.0 ; priming
    G1 X125.0 Y280.0 E12.5 F1000.0 ; priming
    G1 Z0.5 F1000.0
    From duet panel I can home everything in the right condition
  • Moderator
    What's in homeall?
  • ; homeall.g
    ; called to home all axes
    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Mar 01 2020 23:52:57 GMT+0100 (Central European Standard Time)
    G91 ; relative positioning
    G1 H2 Z-5 F600 ; lift Z relative to current position
    G1 H1 X-305 Y-305 F1800 ; move quickly to X or Y endstop and stop there (first pass)
    G1 H1 X-305 ; home X axis
    G1 H1 Y-305 ; home Y axis
    G1 X5 Y5 F600 ; go back a few mm
    G1 H1 X-305 F360 ; move slowly to X axis endstop once more (second pass)
    G1 H1 Y-305 ; then move slowly to Y axis endstop
    G1 H1 Z355 F360 ; move Z up stopping at the endstop
    G90 ; absolute positioning
    G92 Z350 ; set Z position to axis maximum (you may want to adjust this)
  • Moderator
    You have your Z axis inverted. The bed in the corexy drops away from the nozzle during a print, but it's still moving in Z+ direction.
    Your homeall file is set to home to Z max and your Z endstop is configured for Z max position, but is your Z endstop actually at the opposite end away from the nozzle?
  • How to solve the problem?
  • Moderator
    @Dav said in Z Problem Corexy:
    First I need to know where your Z endstop is located.
  • Up near xy axes, from here I manual level my bed with springs.
  • @Phaedrux my y 0 is on the back left corner also
  • Moderator
    Ok that's going to need some changes as well. Here's what you'll need to change.
    In config.g the Z endstop position needs to be changed from Zmax, to Zmin by changing Z2 to Z1. Same with the Y endstop, from Y1 to Y2.
    You have:
    Should be:
    M574 X1 Y2 Z1 S0 ; set active high endstops
    In homeall.g you need to invert the direction of your Z and Y movements and change the G92.
    G1 H2 Z5 F600 ; lift Z relative to current position
    G1 H1 X-305 Y305 F1800 ; move quickly to X or Y endstop and stop there (first pass)
    G1 H1 Y305 ; home Y axis
    G1 X5 Y-5 F600 ; go back a few mm
    G1 H1 Y305 ; then move slowly to Y axis endstop
    G1 H1 Z-355 F360 ; move Z up stopping at the endstop
    G92 Z0 ; set Z position to axis maximum (you may want to adjust this)
    Now when you've made those changes we need to test the motor movement direction BEFORE you home the printer. So after you've made those changes, power off the printer and physically move the print head to the center. Manually lower the bed as well so that it's not close to the nozzle.
    Now turn on the printer and send these commands in the gcode console. DO NOT HOME THE PRINTER YET.
    Send G92 X150 Y150 Z10
    Then use the jog buttons to test the movement direction.
    X+ should move to the right, X- to the left.
    Y+ should move to the bacm, Y- to the front.
    Z+ should lower the bed, Z- should move the bed towards the nozzle.
    If all those movements are correct, you can try to homeall, but be ready to cut the power in case something goes wrong.
  • @Phaedrux said in Z Problem Corexy:
    G92 X150 Y150 Z10
    With Y2 my y going to the wrong way to home.
    also the Z going to the wrong way now.
    ; Hotend
    ; homeall.g
    G92 X150 Y150 Z10
    sorry y it's ok now only z same problem
  • Moderator
    Ok, if Z is going to wrong direction, we now need to change the motors rotation direction to get it going the right away again.
    In the drives section you have:
    Change it to: M569 P2 S1 ; physical drive 2 goes backwards
    X and Y are moving the right directions though?
    If homeall is working, you'll also need to make changes to the individual homex homey and homez files.
  • @Dav said in Z Problem Corexy:
    yes changed
    P2 and now works, i've also inverted the endstop of my Y in another way works in the wrong way.
    Now is printing
  • Moderator
    @Dav alright. As long as Y+ moves to the back of the printer you should be ok. Otherwise you may get mirrored prints.
  • My home is back left for x and y. From here if I click x+ my x goes to right, if I click to y+ it comes to me from the back to the front
  • @Phaedrux from what I see in your picture my y is inverted from your.
    Is this OK? My endstop is on the back left and not in the print like your
  • @Phaedrux
    I'm a little confused, I follow this cabling
    the problem is that if I conect x motor to x connector in duet board and y motor on y connector, if I move x on console it moves the y and vice versa...why?
  • CoreXY always moves both motors. The only move that turns one motor and not the other is an exact diagonal (turn the motor by hand and you will see which diagonal).
    So with one motor plugged in, either one, you will always see that individual motor turn, even though you commanded a "straight" move.
  • @Dav Is that your actual belt diagram? If so, you've got more than Z axis problems. The belt tension will vary with extruder carriage position, and that means the X and Y axis relationship will wander (belt tension is what keeps the axes square), and prints will be distorted.
    The problem is that the segments of the belt that vary in length depending of extruder carriage/X axis position are not parallel to the guide rails. In this diagram, belt segments labeled A-H have to be parallel to the guide rails. The other segments don't have to be parallel to the rails.
    When you set up the Z axis screws, you didn't even think about putting them in a position that wasn't parallel to the guide rails. Belts work the same way. Compare your diagram to the one above- almost none of the segments that need to be parallel to the rails are parallel. The working side of the belt loop has to be parallel to the guide rails in any linear motion system.
    More info on proper corexy layout here: https://drmrehorst.blogspot.com/2018/08/corexy-mechanism-layout-and-belt.html
    Don't worry about it, this is an extremely common error that is probably the cause of many people thinking that there's something difficult, tricky, or magical about corexy printers.
    I have collected a bunch of photos and computer renderings of incorrect corexy mechanisms. You can see them here. You are not alone...
  • Moderator
    That's not correct.
    Please do these motor tests as described here: https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
    These should get you sorted out.
    It would also help if you posted a photo of your printer perhaps. If possible mark it up with the positions of the endstops and the axis limits.
  • @Phaedrux found the problem, for si of all connected x motor on x connector and y motor on y connector, I changed the y direction, now if I click - is coming to the front like you ask me to check.
    I think everything working now.
