    CAN extruder controller
    Hardware wishlist
    • Agniusmundefined
      Agniusm
      I was wandering if there is no interest to make CAN extruder head module that would take 2 power lines and 2 data lines so only 4 wires goes to extruder rather than tens? I would imagine the board would have NEMA17 footprint with multiple outputs and probably extruder motor driver and bolt on directly onto motor back in DD situation. I am no engineer so just brainstorming. If i am correct duet supports CAN commands natively so only decoder would be needed?
      • jmjcokeundefined
        jmjcoke
        https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board
        Joshua Coke
        Trick Laser Metal Max with Smart Effector
        Duet Wifi
        Zesty Nimble
        Mosaic Pallette+
        At work
        Renishaw AM250/400/ RenAM500M/500Q Powder Bed Fusion (Metal 3D Printers)
          droftarts administrators @Agniusm
          @Agniusm Already exists! Only two wires go to the head, though. Which is even better. Duet 3 supports CAN, Duet 2 does not.
          See https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board
          dc42's blog on fitting them: https://miscsolutions.wordpress.com/2020/03/02/converting-the-e3d-tool-changer-to-duet-3-with-hemera-tools-part-1/
            dc42 administrators @droftarts
            Actually 6 conductors go to the head: 2 power wires and 2 twisted pairs for CAN. But I'm hoping we will be able to eliminate the second twisted pair in most situations.
