extruder 0 reports no filament
  • What can cause an "extruder 0 reports no filament" message and the printing to pause? The printer has a standard switch type filament sensor and isn't running out of filament. If I press resume the print resumes without issue.
  • Intermittent switch or wiring ? I have experienced that before where there was an intermittent and very short interruption in the signal. The printer sees it and by the time you get to it the signal is back to normal.
